Bose audio wiring
Old Jul 29, 2017 | 08:43 PM
oakley1984's Avatar
oakley1984
Bose audio wiring
Yes, i am aware there is a sticky laying out all the wiring for the bose audio system, im actually kind of curious about something else, and perhaps someone here on the forums has dug around enough and found exactly what im looking for, is anyone aware of an adapter that you can use to adapt the factory low level inputs into the bose amp, and use a plug n play solution of going from the factory wiring harness, to rca's ?
https://www.sonicelectronix.com/item...EM-GM1416.html
^ that is the exact thing im looking for, just need one for infiniti / bose system for a 2011 coupe
Old Jul 31, 2017 | 01:04 PM
Entcee's Avatar
Entcee
If you tap into the wires before the amp, they are low level and you can just tap in RCA's.
Something like this will give you what you want.
Link Link
Old Jul 31, 2017 | 04:28 PM
oakley1984's Avatar
oakley1984
yeah im well aware i can tap into the factory harness and do that, the exact point of this post was attempting to NOT do that and destroy the factory harness. Theres absolutely no reason why there isnt a plug and play method.
Old Jul 31, 2017 | 04:37 PM
Entcee's Avatar
Entcee
Sounds like you would need to source factory connectors to make your own harness. I think sourcing the connectors will be the hard part.
I am guessing that 99.9% of G owners just spice the wires. I can confirm this does not destroy the harness.
Old Aug 1, 2017 | 10:37 AM
Landshark's Avatar
Landshark
Posi-taps. So easy and awesome. no destroying of harness.
i even moved my taps from the rear speaker wires to the fronts
Old Aug 1, 2017 | 04:59 PM
vaio23's Avatar
vaio23
Yes, was looking for one also but had no luck. I will end up using positaps. Below is the one I bought for my BMW
Old Aug 3, 2017 | 07:48 PM
oakley1984's Avatar
oakley1984
ah well, guess ill be pulling pins and soldering rca's direct into the plugs, thnx everyone
