KP technologies module blowing fuses
Old May 22, 2017 | 06:32 PM
HotSawce's Avatar
HotSawce
So I've recently attempted to install my Mirror tilt module from kp technologies. It has 8 wires. Constant 12V, ignition 12V, reverse 12V, ground, and 4 wires for mirror inputs and outputs. There is a fuse in-line with the module's constant 12v wire.
For some reason, after connecting all of the wires to their respective, proper locations, and then reconnecting the battery, the fuse on the module blows. I've tried 3 different grounds with 3 different fuses and it continues to happen. The constant 12v source I used is the one recommended by them, for our cars. It is found in the BCM.
Can someone explain why this happening and how to fix it?
Old May 24, 2017 | 02:01 PM
jpowersjr2's Avatar
jpowersjr2
I would contact KP and browse through their forums.
Old May 24, 2017 | 03:17 PM
dwb993's Avatar
dwb993
What Amp rating is the fuse? They sent me the Independent Foglight module with a 2 or 3A fuse that kept blowing. I upped it to a 5A fuse and it has been fine ever since. Just remember to make sure your wiring can handle the additional amps and try to keep the rating as low as possible without blowing.
Run this all by Kevin before you implement. He may have additional advice.
