Audio, Video & Electronics Reviews on G Audio, Video, and Electronics.
Review Shorai lw lithium iron battery LFX36L3-BS12
Old Apr 1, 2017 | 09:54 AM
sc10692's Avatar
sc10692
Battery packs huge punch for the size. Weighs over 20 pounds less then oem. Has had no issues starting my G (2013 S sedan 6mt) in 0 degree weather after sitting out all night. I drive pretty much everyday so idk how long the battery would last in the car sitting but it hasn't let me down. Somewhat slow to crank after sitting over night but that's the nature of lithium batteries( crank harder as they warm up). Install was simple you can reuse the stock j-hooks as long as you space the battery, I'm using a roll of electrical tape lol you will have to remove the connector on the positive harness to connect to the battery but that's it. If your G is a track car or stays on the charger you could definitely get away with one of the smaller ones but for a dialy this is the smallest id go.
Amazon Amazon
link to terminals I used
g37 - Album on Imgur
Sorry mods posted in wrong section, don't know how to change it
Old Apr 1, 2017 | 07:02 PM
PNW_IPL's Avatar
PNW_IPL
Nice. Curious why you went with this vs normal battery
Old Apr 1, 2017 | 08:34 PM
sc10692's Avatar
sc10692
Weight savings, less weight makes everything better. If i can cut alot of weight and still have enough juice to start the car thats a win to me. Price wasn't too bad either.
Old Apr 1, 2017 | 08:56 PM
PNW_IPL's Avatar
PNW_IPL
How much?
Old Apr 2, 2017 | 01:02 PM
zer099's Avatar
zer099
I went with a Battery Tender BTL35A480C, last year. Been working great. It weighs 3 pounds. It cuts a huge amount of weight from your front end. Cost was in the $200 range. Most Lithium batteries that will work with our car will be in that weight range and cost area.
Old Apr 4, 2017 | 06:17 AM
sc10692's Avatar
sc10692
How much?
Paid around 250 on amazon
Old Apr 18, 2017 | 09:28 PM
ezbme's Avatar
ezbme
Damn, I have looked at these before, but I wondered how something with 170 cca could start a car.
Old Apr 19, 2017 | 12:10 PM
zer099's Avatar
zer099
The LFX36L3-BS12 is 540, the BTL35A480C has 480. Where you getting 170 from?
Old Apr 19, 2017 | 02:21 PM
ezbme's Avatar
ezbme
Not sure it was that one, but how do we compare lithium batteries with traditional ones when it comes to CCA? What is the longevity. I saw an article from Motor Trend. I guess our charging systems weren't made for these kind of batteries. How did you fit a smaller battery in?
Old Apr 19, 2017 | 03:08 PM
zer099's Avatar
zer099
Fair point, I don't think a "standard" has been made yet by the SAE. Mine's been in the car for almost a year, no issues. I drive the car everyday, and have left it twice for a week untouched all with no issues starting. Cold starts were only around 19 degrees this year, but it did fine. For fitment I got a set of posts for the leads to go too, made a step for the battery to sit on, ordered a top-strap to fit the new battery, and retrofitted some battery posts from an old build.
Old Apr 20, 2017 | 08:38 PM
dwb993's Avatar
dwb993
Somewhat related question: Does anyone know if a Battery Tender Plus 12V PN: 021-0128 will work with these types of batteries? I don't see anything specific on their website.
Old Jan 6, 2018 | 10:23 AM
ezbme's Avatar
ezbme
I wish my battery hadn't been acting so poorly. I replaced mine last year. I would love to lose 30lbs, my car would too. I am hearing things like improved fuel economy. Have you seen any better mpg?
Old Jan 6, 2018 | 05:47 PM
slartibartfast's Avatar
slartibartfast
OP, you might to fix the title of this thread. Lithium Iron?
Old Jan 7, 2018 | 11:38 AM
zer099's Avatar
zer099
To his defense, lithium iron phosphate is a lot to put in the title and LiFePO is like a cryptic language to many.
ezbme, I say no change in fuel economy with my battery. It did make corner balancing the car easier.
dwb993, Battery Tender says this when charging their LiFePO batteries:
a) Do not use a desulphation or pulse charger, doing so will damage the
battery and void the warranty.
b) Standard lead-acid chargers may be used, as long as they do not exceed
14.8Volts during charging.
c) Maximum charge rate is 10Amps.
d) The use of a lithium specific charger such as the units in the Battery
Tender® Lithium Charger series is strongly recommended
e) Do not allow the lithium battery to discharge below 8Volts as this will
damage the battery and void the warranty.
f) Do not charge the battery in temperatures below -10ºC (14ºF).
Old Jan 7, 2018 | 12:02 PM
slartibartfast
Thanks for the 411, zer099. I didn't know LiFePO was a thing. I thought OP meant lithium ion.
