G37 Coupe - Problems with Radio
Old Oct 3, 2016 | 04:30 PM
Su_G37's Avatar
Su_G37
Hi, I have a 2008 G37S just reached 100k miles and i'm noticing weird issues. The radio completely has no sounds coming out of it. AM, FM, iPod whatever I try, no volume. At the same time, the blinker also only makes the clicking sound once in a while. Not sure what's going on, I'm guessing the radio is broken? Can someone give me some ideas on how to get this fixed?
Old Oct 3, 2016 | 04:48 PM
Elco's Avatar
Elco
when you turn the volume **** can you see the volume bars on the screen? or not?
Old Oct 3, 2016 | 05:06 PM
Su_G37's Avatar
Su_G37
Yes, I can. And the song looks like it's playing, but no sound at all.
Old Oct 3, 2016 | 05:16 PM
Elco's Avatar
Elco
If you have the bose version, it might be something related to bose amp. If you have the base version, without navigation and bose, then is a faulty AV head unit...
first, check the fuses under the dash and the fuses from IPDM-er (located betwen the battery and the fender)
IF the bose amp or head unit is bad, get a cheap used one from e-bay... a new one at the dealer will cost you a fortune...
Old Oct 4, 2016 | 12:52 PM
Su_G37's Avatar
Su_G37
I don't have the version with Navi, but I do have a Bose sound system (well the rear speakers say bose on them, as well as the ones in the front).
Is this the part I will need?
2008 2009 Infiniti G37 Am FM CD Navigation Radio LKQ | eBay
Old Oct 4, 2016 | 03:41 PM
Elco's Avatar
Elco
it might be the bose amp problem.. the head unit is kind'a bulletproof...
Better take it to a technician to take a luck at it...
The repair might be cheaper than you think...
Old Oct 6, 2016 | 11:13 AM
Kris9884's Avatar
Kris9884
Probably a loose connection or fuse.
Old Mar 2, 2019 | 06:02 AM
Cappercee's Avatar
Cappercee
Elco I’m having the same problem and my volume is not moving?
Old Nov 14, 2019 | 09:14 PM
Khalid Popal's Avatar
Khalid Popal
Did you ever figure out why no sound is coming out
i have a 2008 g37s coupe with the same problem it’s playing and the volume is going up but no sound at all
Old Jan 31, 2022 | 05:31 PM
Arey10304's Avatar
Arey10304
Hello guys,
Did anyone ever figure out a solution for this? I have the same no sound coming from my radio issue. ​​​​​​ I found a post on another board linked below, where a guy says he fixed it by resetting it with an obd scanner. Can anyone verify if they did anything different? I dont want to buy a AMP when i suspct that it isn't the issue. Thanks in advance!
https://www.cargurus(dot)com/Cars/Di...42602_ds953220
Old Feb 17, 2022 | 06:05 PM
helpmepleasee's Avatar
helpmepleasee
Originally Posted by Arey10304
Hello guys,
did you fix it
Old Mar 12, 2023 | 02:08 PM
miamiamia15's Avatar
miamiamia15
did you ever fix this issue? I’m having the same one!
goldeneaglesvc
Feb 5, 2019 11:36 AM
Murdacopa
Feb 10, 2017 08:55 PM
SneakyBrown
Oct 13, 2016 06:48 PM
ace3058
Sep 9, 2016 04:44 AM
15jeffreyr
Sep 5, 2016 05:31 PM
