Hardwire radar detector
Old Apr 18, 2016 | 03:08 PM
Weedy38's Avatar
Weedy38
Does anyone have pictures and steps of how to hardwire a radar detector. I have the escort max 2 and it's in the dash and I want to put it up by the rear view mirror? Thanks
Old Apr 18, 2016 | 03:58 PM
serega13's Avatar
serega13
I have it mounted using a rear mirror bracket with wiring tucked under headliner and a-pillar panels and plugged into the fusebox, took less than an hour for the whole thing but you have to have a few parts such as a plug for the fusebox unless you want to make your own. Some people also splice into the rearview mirror wires to get power.
Old Apr 18, 2016 | 05:41 PM
Weedy38's Avatar
Weedy38
Could you send a picture thanks
Old Apr 18, 2016 | 06:03 PM
GeezerB's Avatar
GeezerB
Get a Blendmount & a 6-8" Invisacord. Takes 5 minutes. I don't know why people want to do it the hard way running to the fusebox. Look on the BM site for tons of pictures.
Old Apr 18, 2016 | 07:34 PM
G37sGraphite's Avatar
G37sGraphite
Here is my thread ...I hope it helps
https://www.myg37.com/forums/audio-v...-hardwire.html
Old Apr 18, 2016 | 08:10 PM
Mr_Mer's Avatar
Mr_Mer
This.
/closethread
Old Apr 18, 2016 | 11:40 PM
G37sGraphite
Cause its a more solid and reliable way of doing it, other than sticking a wire in the back of your mirror...
Old Apr 19, 2016 | 11:31 AM
GeezerB's Avatar
GeezerB
Well, I disagree. The cord comes with metal blades that wedge tightly in the back of the plug. It is not visible. I hang a parking pass over the mount monthly & have never dislodged any wires. If you haven't seen this configuration in person, don't disregard it.
Old Apr 19, 2016 | 12:35 PM
blazeplacid's Avatar
blazeplacid
I've done both.
It's preference.
I like the hard wire route
Old May 10, 2016 | 01:54 PM
RANDY350Z's Avatar
RANDY350Z
I have 2 cords to do: an Escort Max 2 and Blackvue dash cam. Can I integrate two into one add a circuit. Both will have fuses in the wiring.
Old May 10, 2016 | 02:00 PM
JSolo's Avatar
JSolo
Just say no!!!!!
^^Neither device draws any significant amount of current. Both should be fine on a 5amp circuit, or even a 3amp circuit.
Old May 10, 2016 | 02:29 PM
blazeplacid
Shouldn't be a problem. Just make sure you don't try to pull more current than the wire and fuse are rated for.
Old May 10, 2016 | 07:17 PM
RANDY350Z's Avatar
RANDY350Z
Cool thanks!!! Is there an open slot on the fuse board that I can use other than the audio/ mirror?
Old May 11, 2016 | 12:14 AM
Epiphany's Avatar
Epiphany
You can run an add a fuse to the "socket" fuse, which is the power outlets. That's where I've got my dashcam running with a 5A fuse.
TjG37s
Oct 13, 2017 01:56 PM
gman69
Apr 18, 2016 10:11 AM
mjnoles1
Apr 14, 2016 09:16 AM
Awgd8
Apr 2, 2016 11:13 PM
Dough1397
Mar 29, 2016 10:41 PM
