Help Bluetooth Audio Streaming
Old Sep 3, 2014 | 01:52 PM
GFTW's Avatar
GFTW
Exclamation Bluetooth Audio Streaming
Hello!!! This is my first thread here
I have a 2012 non-nav G37. I've been doing quite a lot of research on bluetooth music streaming on this forum as well as on the internet. Most of the solutions I found involved emulating the XM radio. I've come across this solution in the link below:
It is exactly what I want to do: just plug n play, no wire cutting involved!
Well, I bought all the things described in the thread, but somehow it didn't work.
So, does anyone here have this set-up working in his car? Or if you have a working solution, please share.
Thanks in advance!!
Old Sep 6, 2014 | 04:16 PM
ross7778's Avatar
ross7778
I'm in the same boat. 2012 non-nav and have found nothing that works just plug and play.
Can't you just use this by itself?
Amazon.com: ViseeO Tune2air WMA1000: Cell Phones & Accessories Amazon.com: ViseeO Tune2air WMA1000: Cell Phones & Accessories
Thanks in advance!!
Old Sep 7, 2014 | 12:14 AM
GFTW's Avatar
GFTW
I tried to connect the tune2air like in the instructions in the link as well as just the device alone. It just didn't want to work.
I also tried to disconnect and reconnect the device multiple times. Some times the audio system tried to read the device but then the screen displayed "check connected device." But most of the times, the system didn't bother reading the device as if nothing was connected to it.
Old Sep 7, 2014 | 03:44 AM
zrixter's Avatar
zrixter
Bluetooth streaming
iKross Multifunction LED Car FM Radio Stereo Transmitter with Bluetooth Handsfree calling and charging . Amazon for ~ 60 bucks.
Old Sep 7, 2014 | 08:46 AM
ross7778's Avatar
ross7778
Did you update the device firmware?
Old Sep 7, 2014 | 12:45 PM
GFTW's Avatar
GFTW
I'm afraid that the sound quality is not good and I hate the fact that with these radio transmitters we have to constantly change the station as we travel out of town. And besides, they do not display song info on the factory screen.
I did not. but I already return it anyway.
I found the "supposedly" newer version of this product called Tune2air WMA 2000. It is, I assumed, only sold in Europe. I don't see any seller in the US that sells this. I wish someone with a G could test this out.
Old Sep 10, 2014 | 10:32 PM
breezethru's Avatar
breezethru
Have you tried this?
https://www.myg37.com/forums/audio-v...ing-power.html
Old Sep 11, 2014 | 10:28 AM
GFTW's Avatar
GFTW
Originally Posted by breezethru
I haven't!!! I wish I knew this set up earlier. I already returned the tune2air WMA1000
However, I plan to buy the newer version, tune2air WMA2000, which has the USB port instead of the 30-pin female port.
My car only has the USB port, not the 30-pin cable like in older G. Hopefully it will work! If not, I might give the WMA1000 another try with the set-up you mentioned.
Old Sep 11, 2014 | 10:29 AM
ross7778's Avatar
ross7778
Let me know how the WMA2000 works and where to buy it. The 2012 G shouldn't need all the extra charging stuff as the USB port provides power.
Old Sep 11, 2014 | 11:06 AM
GFTW's Avatar
GFTW
For sure! For some reason, the WMA2000 is only sold in Europe. I have to buy it from a seller from UK on ebay.
Old Sep 17, 2014 | 05:18 PM
GFTW's Avatar
GFTW
So.... I received the WMA2000 today. I connected it to the car via USB port then to my phone via bluetooth. Unfortunately, it was stuck on "reading file" mode. I gave up now
Old Sep 17, 2014 | 08:13 PM
ross7778's Avatar
ross7778
Don't give up! Update the firmware. What phone are you using?
Old Sep 17, 2014 | 09:29 PM
GFTW's Avatar
GFTW
I think it comes with the latest firmware. And I have an iphone 5s. There is nothing I can do about it now
Old Sep 17, 2014 | 11:44 PM
ross7778's Avatar
ross7778
Did it come with a user manual?
Old Sep 18, 2014 | 12:01 AM
GFTW's Avatar
GFTW
Yea but it simply tells you how to connect the device, which I already knew how.
