Help RADIO - NAV - SCREEN - AC NOT WORKING - Please help
Old Jul 5, 2012 | 11:24 PM
sn4k3d's Avatar
sn4k3d
Hi people,
I have a g37s 2009. The car went crazy suddenly no idea why.
the screen went off, the ac went on, i cant control the radio its off anyway and i cant control the ac and the screen went off no idea why.
only when i turn on the headlights, the ac/radio/nav console light turns on but still cant control any of it and the screen stays off.
I have this same problem everytime i turn my car on, I would like to have your help and i will leave the dealer as a last choice since its very expensive.
any ideas guys what could be the problem and how to fix it ?
I appreciate your help.
thanks.
Old Jul 6, 2012 | 08:42 AM
Dulanicki's Avatar
Dulanicki
They resetting the system by disconnecting the battery, waiting about 5 minutes to ensure full discharge and reconnect. That may help. Also, check to see if you have a blown fuse anywhere. Not sure where they are located however a quick forum or google search will net you an answer. Hope this helps.
Old Jul 6, 2012 | 08:45 AM
sn4k3d's Avatar
sn4k3d
Hi Dulanicki, I will try this now and keep you posted. thank you for your help
Old Jul 6, 2012 | 08:47 AM
Dulanicki's Avatar
Dulanicki
One more thing, make sure you have all the different owner manuals. I believe that by disconnecting and reconnecting power, they radio/Nav will prompt for a code to reactive it (theft deterrent system). If you don't, then you will need to take it to the dealer.
Old Jul 6, 2012 | 09:39 AM
Modme's Avatar
Modme
There is no radio theft code but the window motor will need reset. I doubt disconnecting the battery will help with your issue. I would check your fuses first.
Old Jul 6, 2012 | 09:47 AM
cribbsjy's Avatar
cribbsjy
Shouldn't a 2009 still be under the bumper-to-bumper warranty? My 08s warranty just went out this past May >.>
Old Jul 6, 2012 | 10:10 AM
Rad_Slinger's Avatar
Rad_Slinger
Depends on how many miles are on it too.
Old Jul 7, 2012 | 05:39 PM
sn4k3d's Avatar
sn4k3d
Hi People, the problem is fixed but i was trying disconnecting the battery and connecting it again now i have a problem with the windows , please guys do you know how to reset the windows ??
btw, my first problem was a faulty fuse, 10AMP that is related to audio mirror. thank god and thank you Dulanicki you were right, now anyone knows how to Reset the windows motor ?
thanks guys
Old Jul 7, 2012 | 06:58 PM
sn4k3d's Avatar
sn4k3d
thanks guys
2nd problem solved. thank you guys.
j50ny
Jul 21, 2017 10:46 AM
Rodknock
Sep 7, 2015 03:43 PM
ZachThomas
Sep 3, 2015 01:40 PM
dlc1988
Sep 2, 2015 09:40 AM
