Power questions
Old May 10, 2009 | 12:14 PM
Jereguy's Avatar
Jereguy
Power questions
So i installed 2 12's in my trunk and everything is hunky dory but when it hits my interior lights dim a little. Is my best bet to get a new battery or a cap? My car is feeling sluggish since its gotten a reflash at the dealer. (likely because i used to drive it very hard now its used to my winter driving) but i cant help but wonder if im losing a lot of power. I had an accura TL beside me earlier now he took off at the lights was ahead by half a car before i stepped on it but i still didnt have the jump forward feelin like i usually do. kinda depressing So should i get a cap or battery and do a reset on my ecu and drive it hard?
Old May 10, 2009 | 01:03 PM
oOmikeyboy's Avatar
oOmikeyboy
Your 2 12's are HEAVY, so expect it to feel slower. I would only put 1 12" or 1 10" to keep the weight down. I have no experience with capacitors or anything like that, but a optima yellow top should be good for audio systems.
For your ECU, try resetting it and then driving aggressively for a while so it knows how you want it to drive.
Old May 11, 2009 | 05:46 PM
626_G37's Avatar
626_G37
Is your ground to the battery or to the chasis? Aside from getting a new battery and a cap, grouding it to the battery helps alot.
b2autodesigns
Brakes/Suspension
128
Mar 24, 2018 07:44 PM
Simran Mann
Sep 13, 2015 01:51 AM
Rogue_G
20
Sep 6, 2015 02:43 AM
nethole
Aug 12, 2015 04:08 PM
