two 10's or one 12?
Old Jul 17, 2008 | 12:09 PM
nwryuber's Avatar
nwryuber
two 10's or one 12?
what would be more sound proficient? two 10's or one 12?
do you think either of them added on in addition to what is already in the car will produce noticeable difference? I already have the bose on wheels.
Old Jul 17, 2008 | 12:14 PM
IllLojik™'s Avatar
IllLojik™
One 12 for more deeper bass, two 10's for more precise bass. What do you mostly listen to as far as music genre?
Old Jul 17, 2008 | 12:50 PM
TerribleONE453's Avatar
TerribleONE453
two 10s... boxed correctly
Old Jul 17, 2008 | 01:09 PM
Graham's Avatar
Graham
The 12 will hit lower frequency and give a lower tone boom. Good on house and hip hop. 2 10's will punch more and catch natural drum sounds better, i.e. rock, and instumental music. Depending on the style of box will determine the sound as well. Sealed boxes will have a large frequency range, meaning it you will hear more levels of low frequencies. But will not punch as hard as a ported box. The draw back of ported, is the bass notes will all sound pretty similar even if the songs are different. the ported box producing a lot more bang with identical subs within a specific frequency range. So the ported is more effiecent for producing the loud punch than a sealed box. But you can over come the less effiecent sealed boxes with more power. (choice of amplifier). IMO, sealed will sound best. But if a hard hit punch is all you want, then go with ported. And again if its instrumental and rock is most of your music library go with the 10's, if you listen to rap go with the 12. Regardless the 2, 10's will be louder, you just physically have more surface area. But they just are built for specific frequency ranges. Bigger the surface area the lower the frequency it can hit.
Old Jul 18, 2008 | 09:35 AM
yesongs's Avatar
yesongs
I put a JL audio 500/1 amp and a JL 12" sealed power wedge in my G
The wedge is really a good fit for our trunk space
This addition really brings the system to life IMO - esp when the rear seat deck is opened up
E
Old Jul 18, 2008 | 06:05 PM
shepa's Avatar
shepa
wait the jl audio power wedge boxes will fit into our trunks????
Old Jul 18, 2008 | 09:48 PM
yesongs's Avatar
yesongs
Yeah buddy
I have:
JL Audio PowerWedge CS112TG-W1 12"
PM me ur e-mail if you want a pic of mine
E
Old Jul 18, 2008 | 10:49 PM
dillyyo's Avatar
dillyyo
Where do you guys get your smoke because I really need some of that ****z!! I don't know how else one can come up with such nonsense!
Original poster, please do some research as post is rather ill informed. In short and all that really matters between 2 10's and 1 12 is that you will have more surface area and pick up some extra dB's. The point this poster made about going deeper or more applicable for different music is nonsense. Think 1. do i have the sapce or want to take up the space with 2 10's? 2. Do I want to pay more money for the little bit of extra sound level I will get? 3. Do I want to purchase or allocate the extra power for the other sub (unless your running something in parallel or series)? These are the only questions you should concern yourself with.
Old Jul 18, 2008 | 10:55 PM
dillyyo's Avatar
dillyyo
Please read below and tell me who your hook up is! deeper or accurate? Hmmm, I always wanted my subs, whether 10's, 12's or15's, to play deep AND accurate!
Old Aug 5, 2008 | 12:55 PM
daquilini's Avatar
daquilini
Surface area
2 ten will play louder and depending on excursion they may actually play lower.
Old Aug 5, 2008 | 05:43 PM
prutkows's Avatar
prutkows
better sound quality with 2 10's. wider bass range with 1 12.
Old Aug 8, 2008 | 10:29 AM
daquilini's Avatar
daquilini
Not True
Depending on the sub excursion and box type. Also Boston Acoustics makes a passive radiator for their subs that gives 3db more output at the tune to frequncy without increasing box volume 4 of their 10's work in a half cube sealed. 3 are compatable with the tuned rdiator.
Old Aug 8, 2008 | 07:09 PM
Bushtree's Avatar
Bushtree
2 10"s have a cone advantage so given everything else a constant, the 10"s would be louder.. (assuming exact same subs in comparision, box built to proper specs, power ect..)
therer are lots of variables though, and 90% of it will come down to the install. the enclosure you build for the subs you choose is VERY VERY important.
Old Sep 17, 2008 | 09:00 PM
siperwrx's Avatar
siperwrx
Sorry sir, you are, in fact wrong.
Old Sep 17, 2008 | 11:18 PM
dillyyo's Avatar
dillyyo
Yeah, you are right! Man, you sure do present a credible argument!
