Digital output on premium Bose?
Old Mar 16, 2008 | 10:13 PM
fcarpio's Avatar
fcarpio
Today I heard that you can add a digital output to the factory Bose stereo system that come with the premium package. Can anyone confirm this? Any links? I want to add a digital signal processor and a digital output would be just plain awesome.
Old Mar 16, 2008 | 10:16 PM
$teveNG37's Avatar
$teveNG37
whats that even meannnn!!!!?!?!?!?!?!?!?!?!!?!? I WANNA DO IT TO!
Old Mar 16, 2008 | 10:27 PM
C@ciQ's Avatar
C@ciQ
explain this to me please.
Old Mar 16, 2008 | 10:32 PM
DiamondGCoupe's Avatar
DiamondGCoupe
Geez I swear ANYTHING that can possibly be done to this car you guys will do.
Don't forget to change your tire cap covers to those nifty color changing ones they sell at DAP.
Random **** FTW!
Can we get a thumbs down smilie.. FOR THE LOSS
Old Mar 17, 2008 | 12:28 AM
majin ssj eric's Avatar
majin ssj eric
^^^^Agreed...
Old Mar 17, 2008 | 03:34 AM
$teveNG37's Avatar
$teveNG37
lol funny thing is i was being sarcastic about it haha. i only need tinted tailights and im straight o and a little thing people might call Turbo charger.
Old Mar 17, 2008 | 01:20 PM
fcarpio's Avatar
fcarpio
bump, anyone?
Old Mar 18, 2008 | 12:36 AM
dillyyo's Avatar
dillyyo
A digital output can be added to ANY digital source. Some are easy premade hook ups and some just need to be located. Anyways, if your keeping the stealth look, do you really not want to be able to use the volume **** on the radio?!
Old Mar 18, 2008 | 10:56 PM
fcarpio's Avatar
fcarpio
Well, my DSP has a volume control that can be mounted anywhere. Can you point me to any websites that have a solution for me?
Old Apr 1, 2008 | 11:00 AM
dillyyo's Avatar
dillyyo
Are you comfortable with taking your HU apart and doing some soldering to add a Tos link cable? Does your DSP have digital inputs?
Old Apr 1, 2008 | 09:14 PM
KahnQuistador's Avatar
KahnQuistador
These are two features found on the Rockford Fosgate 3Sixty.2:
- on-board digital signal processor
- dash-mountable volume **** and source selector
You might go to their site and check it out. I think they have downloadable manuals/specs for it.
Good luck.
Old Apr 2, 2008 | 12:52 PM
quart's Avatar
quart
Two points... I would like to hear more about this Digital output and if it is true, could open up tons of possibilities for connecting aftermarket gear. USing a good outboard D-to-A converter one could feasibly keep the stock sources then feed amps and speakers with minimal cutting of wires etc.
As for the 3Sixty's... I have used them and they are great products. However they do not have a digital input. They take speaker level inputs(analog) and process them into the digital domain and then convert them to RCA (analog) outputs to your amps. Thus 3Sizty's are an A-D-A converter
If our cars had a digital output, even one that we had to solder the right connector on to, we could use some realy nice stuff to do the same thing as the 3sixty, but minus the analog into digital step that you get when taking an analog speaker output and converting it to digital in something like the 3Sixty.
Old Apr 2, 2008 | 05:59 PM
KahnQuistador
Well, the Burr-Brown DAC is a pretty good unit and the ultimate goal is to feed analog to the amps/speakers. The problem, as I see it, is that the head unit controls stink. You can't configure sound with just bass and treble controls and no DSP capability.
It seems to me that modifying the head unit to access the digital output is spending a LOT of money (and risking damage to the head unit) to get very little bang in the end. After all, you'll be driving in a pretty noisy environment, not your living room.
What hardware would you use to process the digital? What would this configuration look like?
I'm going to use the 3Sixty.2 for the DSP and mucho band equalizer, not just to defeat any EQ curve the head unit might have.
I understand the theory but it sounds like a lot of work for little gain. Will somebody explain the work required and the expected benefits?
Old Apr 3, 2008 | 09:19 PM
dillyyo's Avatar
dillyyo
first thing is, the HU has no EQ curve as the signal is flat from the HU. Second, a true parametric or 1/3 octave EQ should be set and forget. Unless you want those 80's Kraco 5 band eq's for messing with, but if your keeping the HU for stealth look then just use a high quality EQ.
As far as losing the one analog to digital conversion step, I agree as your not bound to notice the difference in a moving car. It's a different story if you compete where road noise is not a factor.
Old Apr 3, 2008 | 09:25 PM
dillyyo's Avatar
dillyyo
any car that has a CD player, has a potential digital output. usually you'll have to disassemble the HU and solder a Toslink cable, but if its a digital source then it can be worked with a digital output. The main draw back is loss of HU volume control and if I am keeping this HU for its functioning and stealthness then I am not willing to give that up. Other people who don't care can try this, but would most likly void any warranty.
