Question about transfer fluid & differential gear oil maintenance...
I'm taking my M37x to a very well-reputed local mechanic tomorrow to have some minor brake work completed (remember the scraping sound I posted about a couple weeks ago?), as well as to have an alignment performed and fluids checked/re-filled. They'll be taking care of the oil change, as well (have decided to go with Pennzoil Ultra Platinum).
I just have a few quick questions regarding maintenance of the transfer fluid & differential gear oil; I checked the manual but couldn't find much of anything regarding these particular fluids. The car has approximately 40.5k miles on it; should I plan on having these fluids changed/filled tomorrow, or does Infiniti consider them to be "lifetime fills," much as they do the transmission fluid? I see that most of the members here recommend having the transmission fluid flushed at the 60k-70k miles interval -- should I just plan on having the transfer fluid and diff. gear oils changed at that particular service interval, as well?
Thanks...
Thanks...
I think a 60k drain and fill for both fluids should be fine. I would also consider a tranny flush done by the dealership only at around 60K as well (even though the FSM says it's maintenance-free)
Transfer and diff oil, from what I've seen can be a DIY job if you want to save some money.
Here's a link to the FSM. Pg 58 is for the transfer case, pg 120 for the front diff and pg 165 is for the rear diff.
http://www.nicoclub.com/FSM/M/2011/DLN.pdf
Thanks! I'll just look into doing drain & fills for both of those fluids when I get closer to the 60k mark. What's your opinion on doing the transmission fluid flush at a Nissan dealership? The one in my city is supposedly one of the only Nissan dealerships in the southeast that is qualified to do all maintenance/repairs on the GT-R, so I would hope they could handle a transmission flush, LOL.
And another thing....i love using their loaner cars...beats waiting for service...lol
Simran Mann
09-13-2015 01:51 AM
Cr0tchf4i
08-19-2015 03:52 PM
Badgerman
08-19-2015 02:26 PM
Thirty_Seven
12
08-16-2015 01:48 PM
