FS KW V3 coilovers (RWD)
Old 04-11-2023, 11:22 AM
gokano
gokano's Avatar
Price: $999
KW V3 coilovers for RWD G37 coupes and sedans
Price $999 (new $2600)Approximately 20000 miles
I had these on my G sedan for a couple of years and I was very satisfied with the ride and performance, no issues
Note for G sedan owners - comes with KW "extenders (purple/black parts shown in second photo):
- This KW V3 kit is designed for the G37 Coupe but will work on the G37 Sedan as in my case with KW "extenders" for the rear springs
- KW rear extenders are included which will prevent the rears from dropping very low even when adjusted to their highest setting without the extenders
- If you have a sedan and want a drop in the 26" (from ground to fender arc) or lower range, you also have the option to install without the extenders
- If you have a Coupe, you will install without extenders.
Local cash meet up in SF bay area, located in midpeninsula / south bay area (shipping will be very high due to size and weight)
DM or text (six 5 zero) nine 9 six - 5 two three 9
gokano is offline
Old 04-11-2023, 04:41 PM
AnotherVQ
AnotherVQ's Avatar
Check your rates on pirateship. I've seen good discounts, even on large/heavy packages.
AnotherVQ is offline
Old 04-11-2023, 10:23 PM
gokano
gokano's Avatar
Thanks for the tip AnotherVQ
gokano is offline
AnotherVQ (04-11-2023)
G37Pillow
07-19-2015 04:07 PM
bsaot
05-17-2015 10:13 AM
Dnovz41
04-29-2015 07:31 PM
grojas112
01-15-2014 11:15 PM
Quick Reply: FS KW V3 coilovers (RWD)
