Computer Re-Learn After Air Filter Replacement
So, my dealer is trying to convince me that I should perform a computer re-learn after they replace the air filter in my car. He's stating that it will help the car to regain some of the performance that it lost in dealing with a clogged filter. This costs $170.
Has anyone done this, at the dealership or on your own? And was it worth the trouble/cost?
This sounds like a simple ECU Reset which you can do for Zero $'s. It's basically unhooking the battery for a period of time (I'd guess 15-30 min's, but I'm not sure) to reset the ECU. You'd loose all of your radio presets and a few other thing if you do it this way.
But there's another way it can be done without unhooking the battery. Here the link to doing it without unhooking the battery: https://www.myg37.com/forums/d-i-y-i...isconnect.html
I'f I'm mistaken, I'm sure that others will chime in and correct me.
$170? My god your service manager must think that you're a moron
There's also a youtube video of an owner demonstrating the timing if you don't want to disconnect the battery.
It is less than a 5 minute job for both of them
Telcoman
holy crap, the G37 has the EASIEST to change air filters of any car i've owned. my last car was a PITA - you really had to wrestle with it.
probably one of the main reasons i never got a CAI for this car (and the fact i didn't want to pay $400+ for 2 extra hp )
OP - the fact that you brought your car to the dealer to replace your air filter shows him you don't know much about car maintenance/repair, and thus he tried to swindle you with that B.S. "computer relearn". read you owners manual, and the DIY section here, and learn to do some things yourself ... and save a LOT of money.
Thanks to everyone for the replies. I should point out that I've changed the air filter in my car before and know how to do so. It's the computer relearn part that threw me off. I was just wondering if there was any value in that or if it was just another attempt at a swindle by the service manager.
if you buy a cold air intake with a different MAF housing diameter, or one that situates the MAF near a major bend in the piping, you might need a tune, but just replacing a panel filter with the same or similar won't require you to do anything extra.
i threw in some R2C black hex panel filters (no oil, clean and reuse) in my G, and everything is fine.
the computer will adjust by itself.
