FS: Bright Rear Turn Signal LEDs! Get crisp, bright, modern turn signals!
Old 12-06-2012, 10:18 PM
  #31
TruLux
TruLux's Avatar
I'm interested in buying amber LEDs for the rear turn tail lights.
Do you have any pics of a G using yellow/amber in the back?
Old 12-06-2012, 11:15 PM
  #32
Diode Dynamics
Diode Dynamics's Avatar
I drive an 09 coupe, so correct me if I'm wrong, but I believe that all models have red tail light lenses (not clear lenses) so you can only use red.
Thank you,
Paul
Old 12-11-2012, 09:44 AM
  #33
nick3941sd
nick3941sd's Avatar
PM Sent.
Old 12-11-2012, 10:22 AM
  #34
Diode Dynamics
Replied, thanks!
Old 05-03-2013, 08:37 AM
  #35
RTom919
RTom919's Avatar
Originally Posted by Diode Dynamics
You can mount it anywhere, just make sure it is not touching the weaker black interior plastic. It gets hot like a light bulb. I'd recommend suspending it in place. I would recommend 6 ohm resistors.
Thanks!
Paul
I recently received from you my FRONT switchback led's and resistor kit for my 2010 sedan. I am going to wait to do the rear turns to led. Can you please comment in further detail on how to install the resistors, and a specific recommended mounting point in the front? I know you are stating to 'suspend it in place,' but does that mean let it hang and hope it doesn't touch anything, or try to screw it onto a metal piece inside the housing. If you recommend we screw it in, how do you recommend we do that? I assume super glue won't work due to the heat. I was not able to find a DIY guide anywhere for this. Please help as I am excited to add these into my car! Love your new site layout btw. Makes purchasing very easy (almost too easy...)
Old 05-03-2013, 11:16 AM
  #36
Diode Dynamics
Here is a install video:
As for the mounting of the resistors, with zip ties most of the time you can clearly secure wires away from resistor. Also you can place the zip tie through the hole in the resistor to secure it to any metal. Just make sure you do not have the resistor resting on anything plastic.
-Michelle
Old 05-15-2013, 06:47 PM
  #37
likeaboss
likeaboss's Avatar
Nice video for the installation.
Old 06-29-2013, 07:13 PM
  #38
socialconflicts
socialconflicts's Avatar
what do you guys think of error free bulbs? i have seen that as an option in other car forums.
Old 06-29-2013, 07:21 PM
  #39
Diode Dynamics
"Error" refers to the "bulb out" warning on the dash that occurs in German vehicles, not hyperblinking. You do not need them in Infinitis because Infiniti does not use the German bulb out warning system, which senses bulbs everywhere (fog light, headlight, license plate, etc).
They will still hyperblink unless you install resistors and they are slightly less bright when comparing similar models of bulbs, so we do not recommend them unless you are installing on a German vehicle.
Paul
Old 04-12-2014, 09:36 PM
  #40
RexHavoc
RexHavoc's Avatar
Any options for an amber rear signal for sedans?
Old 04-13-2014, 01:25 PM
  #41
Diode Dynamics
Send us an email for more information: contact@diodedynamics.com
Thanks!
Nick C.
Old 05-04-2014, 02:27 PM
  #42
dgey1
dgey1's Avatar
thank you... order from your website sent.
Old 05-05-2014, 10:29 AM
  #43
Diode Dynamics
Don't forget to post pictures once you have everything installed!
Thanks!
Nick C.
Old 07-06-2014, 01:14 AM
  #44
Goonz
Goonz's Avatar
Just installed the front turn signal XP80 style in my coupe, what a clean look at night! love these bulbs, worth the $100 (which was very hard to convince myself to spend but in the end glad I did)
Old 07-06-2014, 01:36 PM
  #45
Diode Dynamics
Thanks for ordering with us!
Post some pictures when you get a chance! The XP80's are the brightest turn signal LED on the market
Nick C.
Quick Reply: FS: Bright Rear Turn Signal LEDs! Get crisp, bright, modern turn signals!
