Multiple codes being thrown - Any body experience these?
Old 02-13-2017, 07:56 AM
RMB5190
RMB5190's Avatar
Installed Stillen Gen 3 CAI Saturday and everything seemed to be good to go. I went to visit family Sunday and on the way Home I'm hit with:
P0131 - Oxygen O2 Sensor Low Voltage (Bank1, Sensor2)
P0151 - Oxygen O2 Sensor Low Voltage (Bank2, Sensor1)
C1109 - BATTERY VOLTAGE (abnormal)
I've driven about 60 miles with the CAI and everything has been fine. Is this even something that can be related to the CAI install? Other posts and threads by other people who've had this problem never mentioned it happened after a mod. Has anybody else come across this? What was the fix?
I should note, the car is running 100% fine. Not rough, limp, or anything like that. Thanks in advance.
Old 02-13-2017, 08:47 PM
saywat?
saywat?'s Avatar
lol damn dude first u change a parking light bulb and u get error code. now u install a cai and get more codes? talk about bad luck i gotta ask tho how are ur mech skills?
Old 02-13-2017, 10:38 PM
Epiphany
Epiphany's Avatar
Sensors are all plugged in properly and seated fully? If you disconnected battery during install, are the battery clamps on tight?
Old 02-14-2017, 05:26 AM
Surfnazi
Surfnazi's Avatar
Reset it and see if it comes back hopefully you didn't contaminate the maf sensor if so clean them off
Old 02-14-2017, 06:04 AM
RMB5190
RMB5190's Avatar
Seriously, I use to think I was pretty mechanically inclined but now I'm doubting myself. : /. When I had my Mazda, I did everything from the CAI to installing motor mounts so I have a little know how when it comes to turning a wrench. Even wired my own halos after cracking open the headlights.
Everything is plugged and buttoned up. I cranked the battery terminal a little tighter so we will see if that helped. I left the battery unplugged last night and switched the MAF sensors. Maybe I put them in reverse? I drove it 11 miles to my carpool this morning and no lights and smooth driving so fingers crossed.
Got the car and started modding so I could enjoy the process but thinking I'll pay someone to put things in for me from now on.
Old 02-15-2017, 06:19 AM
Surfnazi
Surfnazi's Avatar
You might have not seated the maf sensors tight which could have caused a small leak making the o2 sensor see more air flow
Old 02-15-2017, 07:19 AM
RMB5190
RMB5190's Avatar
How tight is tight? I'm hesitant to crank them any more but i'll see if there is any play.
What are the chances the O2 sensor is bad? I find it hard to believe but I'm a little lost as to what to do next after cleaning TB and MAF
Old 02-15-2017, 09:25 AM
Surfnazi
Surfnazi's Avatar
It's not the sensors more than likely when you put the sensor into the intake housing it just didn't sit flush we all get excited the last 5 mins of an install and overlook small things btw if you lose the torx screws to the maf sensors you can buy a 10 pack from pep boys for 2 bucks
Old 02-15-2017, 09:30 AM
Surfnazi
Surfnazi's Avatar
Also as much as it sucks read insctructions a few times and do installs sober or you'll be chasing your work
Old 02-15-2017, 10:13 AM
RMB5190
RMB5190's Avatar
Lol I hear ya. I save the brews for the end of the project. I'm just baffled that something so simple is causing this many issues. Especially right after changing a bulb and getting a code - who does that?! I feel like you have to try to throw codes after a bulb change haha. I'll be checking everything tonight, Fingers crossed...again.
Old 02-15-2017, 01:44 PM
Surfnazi
Surfnazi's Avatar
They require certain amount of resistance that's why most after market kits come with the resistors
Old 02-15-2017, 03:54 PM
RMB5190
RMB5190's Avatar
Yea, I have the resistors and have them installed.
Old 02-16-2017, 05:14 AM
Surfnazi
Surfnazi's Avatar
Use meter and check oem vs new
Old 02-16-2017, 05:53 AM
RMB5190
RMB5190's Avatar
Well, the codes thrown from the bulb switch is gone. That was a matter of the MAFs being placed back in incorrectly. The new codes popped up about 60 miles after the CAI install.
Old 02-16-2017, 06:11 AM
Surfnazi
Surfnazi's Avatar
Make sure all your silicone fittings on the intake pipe are tight
