does any one know if the g37 has relay for the ac
quick question i was wondering if anyone know where to locate the ac relay,if possible. i located the ipdm and fuse box on driver side i blew two 15 amp fuses for the blower so im on the shake down for the ac relay if possible.
thanks
thanks
The relay for the compressor should be on the IPDM, but hard to tell from the service manual... The one for the blower motor (inside cabin) is on the back side of the fuse block / junction box near drivers left leg.
Juelz86g37s2012 (12-20-2016)
ok cool be cause i located the ipmd box. no dice just the ac fuse 10 amp.
However i did locate 2 blower fuse in the driver fuse panel(foot/stand ) .so im guessing I will have to remove the fuse box from driver side to gain acess behind it.
thanks man will do and Holla back
removed the fuse box off the bracket and the wiring loosen the 10.mm nut examined the relays all seemed goo install.new fuse in the blower slots 15 amp then i proceed to ch3ck my blower motor and this was the cause for me the whole unti itself was indeed shot. .
thx again
thx again
Thanks for the report, it sounds like you've found the trouble...?
Are you saying your blower motor has failed and popped the 15A fuse? And a new fuse didn't fix it but immediately popped again?
If that's the case, before you order a replacement fan ($$$) you should pull the glove box and check that your cabin filter is correctly in place. Make sure the filter, or anything else, has not fallen down into the blower (which is directly below it) and jammed it. Just an idea.
Juelz86g37s2012 (12-21-2016)
yeah bro thanks alot after pulling the fuse panel i added 2 more 15amps and a 20amp come to find out the previous owner shoved a 20 amp fat fuse in the place of these tiny fuse.
it blew my blower motor .i brought a new blower motor and it fix my problem. .,thanks,again bro.
Well, I saved myself some $$ by coming here and learning about the relay location, (needed on accouta the blower no workee..)
so now I'ved got the fuse block out, but can't rotate it to get to the relay
without pulling a plug on the front side, which I tried to do but was stymied..
and can't use my fingers and thumbs to "push" out the gd relay from the front side.
Still recovering from a spinal fusion hasn't helped.
So it's about time to go out and give it another try.
Think I'll take some pliers with me.
