Constant suspension knocking noise..
Old 09-23-2016, 06:30 PM
iCrap
iCrap's Avatar
So, every time I leave my garage, go over a bump, go on a bad road, or even sometimes make a turn i hear this constant knocking / clunking noise. Seems like any time the car has a side-to-side motion, I get this noise.
The car has the Hotchkis front / rear sway bars, KYB struts and Eibach springs. The rear endlinks are aftermarket ... but i forget the name. I THINK they are SPL endlinks (they are orange.) The front endlinks are stock, never changed. This is a problem i've been having for the past few months, but i finally tried to find the source of the problem today, with no luck. The noise started after lowering the car, but not immediately... about a month later.
Anyone have any ideas? I checked all the bolts today, endlinks are tight, nothing is visibly loose or broken. I feel like it HAS to be something related to the sway bar / endlinks but at this point I just can't figure out what's causing it. I also can't even pinpoint it to the front or the rear, all i know is it's coming from the passenger side of the car.
Old 09-23-2016, 06:43 PM
JSolo
Just say no!!!!!
JSolo's Avatar
Lube the sway bar bushings lately?
Old 09-23-2016, 08:04 PM
iCrap
iCrap's Avatar
A few months ago, yea. That's a whole other problem though. The bars have been on since like 2010, so now the nipple things for adding grease are totally just clogged up, beyond repair. I have to detach the brackets and add grease that way.
I also read some other stuff online saying you're supposed to extend the front / rear endlinks to remove preload from the bar... I never did that, and mine are still stock length so maybe that could be causing a noise too?
Old 09-23-2016, 09:44 PM
MaQG37
MaQG37's Avatar
First thing I'd check is the front end link. I have Eibachs, Hotchkis sways, exact issue. The front end only makes a small clunk when going over bumps and stuff.
Old 09-24-2016, 12:24 AM
iCrap
iCrap's Avatar
I'll check it. I took off the wheel and tried to move the endlink around to see if it had any play, but I didn't actually remove it completely and look at it. It's possible it's gone bad.. 102k miles on the car and that's still the factory end link.
Hdinh94092
07-03-2017 02:28 PM
2five8
18
05-26-2017 05:40 PM
pcwd
14
09-11-2016 10:56 PM
Presto
09-08-2016 04:00 AM
wmvG37
09-04-2016 07:10 PM
Quick Reply: Constant suspension knocking noise..
