Transmission Fluid
Transmission Fluid
Long time lurker of Myg37 but finally made an account as I finally needed to ask a question I couldn't find an answer for.
My 2011 G37x is at the dealership right now for the transmission fluid to be changed. The car has 20,000 on it so I know it has the factory fluid. My question is, is there a way to actually figure out if they completed the service? Is there a factory seal that must be broken on the drain plug or the location at which they put the new fluid in at?
I guess I have some trust issues but it's one of those things that could easily go unnoticed. Thanks guys!
EDIT: 4/23/15 So I figured I should add this to the first post to change the direction of the thread since I've had great results so far. 2 days have passed since the transmission fluid was changed. Shifts are so much better to the point where I'm questioning if the tech did the TSB software update without saying anything.
EDIT: 4/28/15 Conclusion
Well guys in summary to this whole experience I can't recommend the trans fluid replacement as a fix for what I was looking for. Most of you probably fit into this category but that being said I would recommend it to those who:
A. Need it changed out as for a maintenance interval which seems to be around 60xxx to 80xxxx miles.
B. Those overkill folks like myself wanting to rid the transmission of break in particles and a slight increase in smoothing out the shifts.
The shifts being smoother overall is nice but still not a fix to the quirky ECU especially during spirited driving. This could also be due to driving like grandma 70% of the time and then asking it to go into teenage race mode. My next step from here is a few more air distribution upgrades then off to a tune at R/T tuning in hopes of getting the car to drive like I want. I've been eying up the motordyne intake manifold and some HFC's the rest will remain bone stock.
Were you having some kind of issue with your transmission that necessitated a fluid flush and refill?
I have an 09 G37x with 55k miles and never needed to change tranny fluid.
My dealer says it never needs to be changed.
The differential fluid should be changed at 75k miles.
Are you sure its not the diff.
Either way this service should not be happening with so little miles.
The same lag everyone else seems to have. I was taking a shot at seeing if this could alleviate any issues.
That lag should be dealt with by TSBs and grounding kit first. Grounding kit would have been much cheaper and easiest to deal with. Most would suggest that if you do get the transmission fluid changed it would be around 75k to 100k. Almost all tranny lag issues in the forums have had the TSB and grounding kit as primary solutions.
I do indeed have the grounding kit made up and installed but just wasn't enough for me. Anyway the fluid is now changed out as of today. I asked for them to check for an update and said none existed so I didn't push the subject. So far the car feels great but most likely due to the ECU being reset and a recent throttle body and MAF cleaning. I will give an update after about a week to report if it returned to its old ways.
blnewt (04-22-2015)
Approximately $215, about $100 in synthetic ATF, $30 flush kit and the rest in labor and tax. Car ran like a top this morning trying not to get my hopes up until at least a week passes. Anyone know if a factory filled transmission from 2011 uses a synthetic blend or pure synthetic?
Here's the service bulletin addressing fluid discoloration
http://www.infinitig37.com/TSB/ITB11-036.pdf
empirepb48 (04-23-2015)
The Fluid should be Nissan Matic-S fluid. I have drained & filled mine 2x since I got it with 40k last year. Changed at 42k, 48k and again at 60k. The reason I changed it was to see if it would help with the shifting as I was having a hesitation on 2-3 shift and sometimes 3-2 downshift. It seemed to help with the hesitation on shifting.
I also want to add that I did the transfer case when I completed the front and rear differentials. The ATF in the transfer case was nowhere near as dark as what's pictured there. That's also based on the assumption that it was still the factory fluid. I'm the 2nd owner so I can't confirm that hence why I wanted a fresh start on all my fluids.
update us on the feel. I have an 09 and i feel the same way as you, that if you do not do it youre doomed for tranny failure at some point. i do not get how the tranny oil doesnt need to be changed????
(added to original post)
