DIY: AWD to RWD Switch
Old 02-15-2017, 02:12 PM
  #31
Inali
Inali's Avatar
Look where I put my switch!
I recently did this mod, and put a switch from a Polaris ATV in a spot where a blank unused switch was located. Take a peek! I tried to purposely hit the switch with my leg. It's almost impossible.
2007 g35x sedan (09-04-2023)
Old 05-02-2017, 09:55 AM
  #32
xscoupe1985
xscoupe1985's Avatar
Originally Posted by Epiphany
You wouldn't change your daily driving dynamics doing this, the car is only awd up to 12mph or if the rear tires slip. It would only affect it during times of traction, which would bring you from awd, to an open diff rwd.
Unless you have a coupe Xs. LSD rear 😁
Old 05-03-2017, 12:07 AM
  #33
Epiphany
Epiphany's Avatar
I'm 95% sure that's not true. I believe the LSD was only available from the factory on the RWD S models.
Old 05-03-2017, 09:05 AM
  #34
xscoupe1985
I read on a thread that they do have it but I'm starting to think it was incorrect. Cuz of the vdc system
Old 05-04-2017, 12:33 AM
  #35
Epiphany
Epiphany's Avatar
Yeah I've seen a few people say they do but I'm almost certain they don't. Infiniti certainly didn't make their packaging and options the easiest to follow on the G.
Old 06-28-2017, 12:17 AM
  #36
G37X-Mars
G37X-Mars's Avatar
will this switch work on a second gen FX?
Old 06-28-2017, 11:28 AM
  #37
Lt8Che
'Cuz Racemod-erator
Lt8Che's Avatar
Most likely. You would have to look at the wiring diagram in the FSM.
Old 02-19-2023, 09:42 PM
  #38
retrohawkin
retrohawkin's Avatar
Ik this is a long shot but is there anyone that can help me fix my car I accidentally blew the fuse by flipping the switch while the car was still on and when i changed the 10A fuse it still wont fix itself don’t know what im doing wrong. its a 2013 g37xs. HELP!!
Old 02-22-2023, 01:03 PM
  #39
Z3us
Z3us's Avatar
What kind of switch do I need, like does it need to have a certain amount of amps?
Old 02-22-2023, 07:33 PM
  #40
Z3us
Z3us's Avatar
Does it matter what kind of switch you buy? Like does it have to be a 10 amp switch?
Old 02-22-2023, 07:50 PM
  #41
ILM-NC G37S
ILM-NC G37S's Avatar
Received 1,253 Likes on 1,015 Posts
Any SPST toggle switch will work. A 10-amp would be more than sufficient.
Old 02-23-2023, 08:51 AM
  #42
beefychicken
beefychicken's Avatar
If you scroll to the top of this thread and look through the pictures you will find a screen shot of a signal table from the FSM. This shows that there are three power inputs to the AWD module. All three inputs are sourced from three 10 amp fuses in separate locations throughout the car. One is in the fuse block behind the drivers kick panel, the other is in the IPDME/R under the hood in the battery compartment and the third is in the fusable link block on the red battery terminal.
Also, still referring the first post in this thread, check to see if your AWD mod switch is inline with the green wire on pin 7 of the AWD module conenctor.
Ther green wire on pin 7 sends power to the AWD module from the start switch circuit so that when the car is turned on the module recieves power on pin 7 and loses power when the car is switched off. Since this puts the AWD mod switch in-line with the start switch there will be less chance of blowing a fuse since the AWD module expects power to be switched on and off through this circuit.
Hope this helps fix your issue, and remember, track use only!
retrohawkin (02-25-2023)
Old 09-04-2023, 07:57 PM
  #43
2007 g35x sedan
2007 g35x sedan's Avatar
So your saying you spliced the green wire and just connected a new wire from there to the switch? so there is only 1 wire connected to the back of the switch and just makes the AWD change from on to off?
Old 09-06-2023, 08:26 AM
  #44
2007 g35x sedan
Lightbulb lost
So please let me know if I am about to do this right before I cut some wires to try to properly wire the switch . Cut the green wire, then does the green wire remaining in wire harness connect to positive end of the switch and the end of the green that is cut and coming from the wire jacket should go to ground on the switch to properly wire this switch so that AWD is always turned on unless the switch is switched? Please someone let me know
Old 09-06-2023, 09:45 AM
  #45
beefychicken
Sorry, missed this reply.
Basically you will be putting the switch inline with the wire, meaning to cut the wire and put one end of the wire to one side of the switch and the other end to the other end of the switch.
Noticed you have an 07 G35 Sedan, You will also need to verify the connector wire positions with a wiring diagram to ensure you working on the correct wire since it may not always be the green wire, especially on 1st runs af a new generation.
2007 g35x sedan (09-07-2023)
mike9630
Intake and Exhaust
20
03-03-2022 06:03 PM
cougarxcguy
05-25-2016 02:42 PM
nishfish871
02-22-2015 09:07 AM
OLPEMI
08-26-2014 05:53 PM
SPDCRZ
12-29-2013 02:38 AM
Quick Reply: DIY: AWD to RWD Switch
