DIY: How to make your own ground wires.
#32
Just did this to my 2010 G37X. Radio definitely sounds louder and shots seems more responsive in manual mode. However, it seems the shifts are faster in gears 1-5 & 6 - 7 are still delayed, but I would think this is more due to these are the OD gears.
Great guide!
Great guide!
#33
Connecting an additional cable from the battery negative terminal directly to the chassis bypasses the battery current sensor, which can impact the power generation voltage variable control system, possibly leading to improper battery charging.
If this causes the alternator to charge too often, it can cause battery over-charging, premature alternator failure and decreased fuel efficiency.
It seems to me like the additional ground to the negative terminal would cause the battery current sensor to see less of the current, making it think there was less battery use, causing it to under-charge. Not only is a weak charged battery an issue for multiple reasons, but on my 'vert could impact the top operation which is very sensitive to battery voltage.
Like many current sensors, the battery current sensor appears to be a "ring" that just sits around the factory ground cable. The factory ground cable seems very thin and the battery current sensor appears to have plenty of room to accept a much thicker cable.
Has anyone tried to replace the factory ground cable from the negative battery terminal to the chassis by running a thicker gauge ground cable through the battery current sensor?
I wonder if the decreased space between the sensor and a thicker cable would cause the sensor to incorrectly sense what it thought was a higher current, causing the alternator to run too much?
SuicidalG37SGuy
09-10-2015 06:01 AM
