DIY: Reversing the shift direction for 5AT
Old 06-18-2008, 04:37 PM
NJKSC27
NJKSC27's Avatar
Originally Posted by LAG37
bump
help!
+1
but i gotta say this DIY sounds shady, might f*** something up
Old 06-18-2008, 10:26 PM
LAG37
LAG37's Avatar
12fear can u explain to me how to remove the pins the last step
Old 06-20-2008, 01:04 AM
J.Oh
J.Oh's Avatar
i need to figure out how to do this..
Old 06-21-2008, 04:24 AM
12fear
12fear's Avatar
Originally Posted by NJKSC27
+1
There should be no reason why this mod will mess anything up. The TCM
is just getting a signal no matter where the switch is coming from just as long as it gets a signal.
Old 06-21-2008, 04:27 AM
12fear
12fear's Avatar
Ok to remove the pins all you have to do is remove the lock on the front of the connector. To remove the lock you would have to pry it up with a small
pick. When you got the lock removed then the next step is to locate the terminals and lift up the plastic lock right above the terminal in the connector. When the lock is lifted then the termianl pin can be removed from pulling it from the rear of the connector. Hope this helps....
Old 06-22-2008, 10:50 AM
LAG37
LAG37's Avatar
if its not a hassle for u
can u take pics of what u just told me ^ step by step please
Old 06-23-2008, 08:55 PM
alti35
alti35's Avatar
+1
I've done everything up to the pin part. I spent a couple of time trying to remove the cables but wasn't able. I'll probably end up buying a terminal pin remover tool or something.
Old 06-24-2008, 09:54 AM
12fear
12fear's Avatar
sure ill take more pictures.
Old 06-24-2008, 03:30 PM
LAG37
LAG37's Avatar
thank u so much
Old 06-27-2008, 06:46 PM
nogoodname
nogoodname's Avatar
to remove the trim around the shift ****, does it have to be in Drive or in Park?
like when you pull the whole thing out
Old 06-28-2008, 08:42 PM
12fear
12fear's Avatar
in the drive position
Old 08-07-2008, 02:45 PM
earth0
earth0's Avatar
Hi! It's might be std question but may i ask what's good thing of this mods anyway.thanks for the advice.
Old 08-07-2008, 11:42 PM
12fear
12fear's Avatar
its just a mod and also feels alot better when you upshift by pulling down the shifter.
Old 08-08-2008, 07:54 AM
  #29
earth0
earth0's Avatar
Thanks! 12fear now i understand the whole instruction.I use to opened the shift couple time with no ploblems.Get me thinking to reverse but i got use to it already.
GL and thanks alot mann!
Old 08-12-2008, 03:45 PM
  #30
amm1232710
amm1232710's Avatar
can u take a pic of the finish product?
Quick Reply: DIY: Reversing the shift direction for 5AT
