TannerGs Build
TannerGs Build
Hello! Thanks for taking a look at my Build. I recently purchased a 2009 Infiniti G37X in Liquid platinum and black interior w/ 51K miles on the odometer. The car is in incredible condition (owned and serviced by a little old lady) and a ton of fun to drive. I've searched the G forum for a few months now marveling at different builds and am grateful for the supportive community here. Anyway I have a lot of aspirations w/ this car and want to make it a refined, clean, joy to drive a look at w/ a ton of power lol. Lucky one of my close friends is a mechanic and used to work on imports and has a ton of tools. So here we go:
Today, 3/5/2016 I made the first step by de-badging the Infiniti and silly dealership decals
Heres a list of some Mods I would like to do. Im still deciding on the specifics so look for updates along the way
Power Mods
Magnaflow or Flowmaster exhaust. Im thinking I'm going to just attach a universal exhaust on instead of replacing the whole system. Any recommendations would be great.
K&N or Injen CAI
Handling Mods
Hotchkis 22443 Sport Sway Bar Set for Nissan G35X/G37X (AWD) 08+
New wheels w/ performance tires
Any Other suggestions would be appreciated
Appearance Mods
Painted black trim- exterior
Aluminum graphite black trim- interior
De-badged (barely a mod lol)
Led interior bulbs
Weather tech floor mats
Painted front grille
Window tint- Still deciding on %
So far thats it. Again any suggestions would be highly appreciated!
Power Mods
K&N or Injen CAI
Handling Mods
Appearance Mods
Led interior bulbs
Today, 5/5/2016 I made the first step by de-badging the Infiniti and silly dealership decals
Power Mods
K&N or Injen CAI
Handling Mods
Appearance Mods
Led interior bulbs
Power Mods
K&N or Injen CAI
Handling Mods
Appearance Mods
Led interior bulbs
I'd definitely recommend some Morimoto XB LED foglights, I've had them since November. They're awesome. If you don't plan on doing a full exhaust, you can throw on some highflow cats. I decided to go with Berks.
Look forward to your progress. As far as Intakes, K&N is a Short Ram Intake (SRI), and Injen makes a SRI (I have that one) and a long tube true cold air intake. The other two common CAIs are Stillen Gen3 and the Takeda CAI.
As far as exhaust, for an X the TopSpeed w/ beveled tips is a good option for about $550 but seems to be constantly out of stock. On a budget you might consider a muffler delete w/ the exhaust tips of your choice.
Have fun w/ your build and shoot a PM if you want to discuss wheels/tires, or a drop.
Brad
Brad
Thanks for the responses, I plan on getting 19" w/ performance tires and keeping the OEM set up for winter driving. I don't plan on lowering the car. I am not going to replace the entire exhaust system but going to replace the mufflers w/ some tips already welded on seeing how my exhaust is in great condition already. Blnewt do you like your SRI CAI? Does K&N only make a short ram intake for the G?
The cold air intakes will merit some gains in hp, somewhere in the 5 to 10 hp seems to be the range give or take a couple hp. This usually comes in the higher rpm range w/ some losses at lower rpms.
The SRIs typically don't have gain, maybe 2 or 3hp, they're mainly for sound and a better look. I do like my Injen SRI, and it uses the OEM flex pipes which are plastic, this can be an advantage over other SRIs since most others use metal pipes which get hotter in the engine bay and are more prone to heat soak (which brings even warmer air into the motor resulting in decreased performance).
19s are a good choice if you don't want to lower your G. There's some nice 19s that shouldn't bust your budget. These Konigs are lighter weight and pretty good looking IMO. You could run 19x 8.5 +33 front on 235/40/19 and a 19x 9.5 ++35 on 275/35/19, the tire sizes give you a 0.67% diameter variance w/ the rear tires being slightly larger diameter, this is great since your rears wear faster, this will bring your variance closer to zero over time.
These are the Flow formed Konigs, they're lighter weight and stronger than regular cell cast wheels, the Rennform, Centigram, and Integram are all available in 19s w/ offsets that will work & pretty nice looking sets IMO.
Flow Formed Wheels - Konig Wheels
If you have more of a budget there's some nice sets from Work (Emotion Line), Gramlites by Rays, and Wedsport, these are about double what the Konigs would run FWIW and are also Flow Formed.
Here's a site that lists many of those wheels
Evasive Motorsports | PH: 626.336.3400 Mon-Fri, 9am-6pm PST: Emotion
Evasive Motorsports | PH: 626.336.3400 Mon-Fri, 9am-6pm PST: Gram Lights
Evasive Motorsports | PH: 626.336.3400 Mon-Fri, 9am-6pm PST: WedsSport
And there's another thousand wheels out there so have fun with it and ask plenty of questions
You can add wider wheels+tires and Swift springs/Coilovers to your handling mods.
Brad
Brad
Any time you have your intake air coming from inside the engine bay it's a short ram setup, the ones that have tubes/filters that extend in front of the radiator it's a true cold air intake.
blnewt (03-05-2016)
blnewt (03-05-2016)
Wow great thank you for all that information. Yeah i had pretty much decided on a full CAI instead of Short Ram after assessing the room clearance today with my buddy we think we can make it work w/o issues on heat sync. That piping recommendation is extremely good stuff and makes sense. So what do the more expensive wheels provide that the Konigs don't? BTW thank you for being very helpful on these posts especially to those who are obviously new. Ive been a part of several forums over the years for most of my cars and most of the time people can be real snobby to those who are new. Its refreshing to see people who still act like people even over the internet.
As far as the CAI, I think the Takeda tends to get the best reviews overall as far as ease of install and the overall fit, cost is pretty good too. I think Brian still has the group buy here to get a nice price~
https://www.myg37.com/forums/group-b...ir-intake.html
As far as wheels, The Japan based wheels such as the Weds, Rays, Work, and Volk typically have very tight quality control and some stunning design and their price reflects that. The Konigs have been around a long time and make a quality product, they have many wheel designs that are plain & basic which are seen on a lot of cheaper cars so that may tarnish their reputation somewhat. Their flow formed line seems to be pretty solid and nice looking, and here's a list of the Top 10 wheel companies from 2013 (which isn't conclusive but gives you an idea that they are a decent brand)
The 10 Best Aftermarket Wheel Manufacturers Right Now | Complex
You've been quite helpful in your time here as well
I like my Tanabe axleback, and I'm pairing it up with Berks HFC next week. I'll upload videos if you're interested, and seeing you're in NC, I'd gladly show you how it sounds in person.
From the video I've seen, Invidia catbacks are relatively quiet. You'll need to get it modified to fit the AWD sedan though.
Are you near Raleigh? I'm over on Camp Lejeune (woooo)
Here's a video that I took of the Tanabe. Everything else is stock.
https://youtu.be/1JNIRqxDyy4
