Rochester's new G
#887
RJM Performance Clutch Pedal Assembly - Installed
https://www.myg37.com/forums/g37-sed...ml#post3933567
MaQG37 (07-29-2015)
#888
Given family vacation plans, and having just spent money on the Camber Arms and RJM Clutch Pedal, it's looking very that I'll be limping down to the Sedan Meet-up with goofy camber and a droopy bum.
#889
I swung by INFINITI this morning for a consultation with their Tech who has been working on my car for things like alignments, an early brake problem, and warranty repair/replacement of the CSC last year. When I showed him the SPC Camber arms, he didn't realize until looking at the install sheet that the bolt holes on the car needed to be elongated, and said the shop didn't have the tools for that. And if he described the mod to the SM staff that the dealership probably would nix it.
So that happened. Or didn't happen, as it were.
Then I walked him through the last 16 months: wheels, springs, spring bushings v1.0, spring bushings v2.0, and my proposal for spring bushings v3.0... putting the 3/8" bushings on the underside of the top-seats (after shaving their inner lips). He also nixed that idea, saying it would certainly address the height objective without compromise to the bushing integrity, unlike the way they blew out between the springs and the top-seats. However, he said there might be some sliding around, even when inside the upper bucket. In other words, it *might* work, but there's an equal chance it wouldn't be safe.
So that (didn't) happen either.
Which brings me all the way back to coil-overs. (sigh)
#891
Yes. But I need to take a big step back and let everything process for a while without whipping out the PayPal account. That means a lot more research. My current situation isn't dangerous... the bushings are stretched out of shape and useless now, but the springs and top-seats are still not going anywhere. So I may pursue CO's this Fall, or I may wait until next Spring.
And if I wait until next Spring, that pushes the 4.083 Gear mod into next Summer, or possibly into 2017.
The Tein Basis are a very affordable CO, but without damping adjustment... which might be OK by me. The car already handles like a beast in its current form, so same-as or slightly better with the Tein setup is very acceptable.
Why, MaQG37? What are your thoughts on the Basis?
#892
#893
John, you could always just install the rear COs and keep the front COs fresh for when the front dampers start to fade. And installing just the rears is a breeze
Like I've said in a few posts the damping adjustment in budget coilovers is a bit overrated. There's such a small window of adjustment that you'd want to drive your car with that it's not as great as it sounds (at least in my experience). Now adjustable KWs or higher end shocks is a different story, and if you do a lot of tracking being able to go firmer is a plus.
In Johns case w/ his sway setup I think having factory set dampers should result in a nice drive.
#894
After getting to know the underside better year over year, I believe you're right that the rears really are an uncomplicated install (for my mechanic, LOL.) I could probably get the camber arms and rear kit installed in 2-3 hours labor, and then another alignment.
I would sure hate to go to the Sedan Meetup next month with the car looking all goofy on both rear corners. Not that anyone would notice unless I force them to see it, but still... *I* see it. And that's kind of the point.
[edit]
The wifey and I have been talking. She hates what I've been doing, customizing the suspension with bushings. And when I told her the Infiniti Tech uttered the word "unsafe" with my latest proposal, she's suddenly encouraging me to get CO's. I suspect part of that is so that I get back to my happy place, and stop moping around because of the car.
Derp.
#897
Mine's not like that, guys. And I wouldn't have it any other way.
I bought the CO's today from Charles at B2AutoDesigns. Apparently when I said I needed to step back and process this situation, I only meant 24 hours. LOL
#900
Yes. Here's my thinking, knock on wood:
Also, as Brad has recommended, I'm planning on just installing the rear shocks & adjustable coils, as well as the SPC rear camber arms. I figure I could leave the car with my mechanic for a day, request he dial the rears to match the 26 3/4" height of the front, then ask the alignment shop for a -2.0* camber on the rears. Next year, I may or may not get a front camber kit for installation of the CO's in the front.
So... a hybrid Swift-OEM/Front, Tein Rear combination. Let's see if that works. If the mismatch is obviously bad, then I continue on with the fronts right away.
It's a hobby after all.
- The price is low, the brand is very respectable, and reviews are positive.
- I'm replacing lowered OEM (sport) shocks with new Tein shocks designed to function with their adjustable coils when lower than OEM height. I figure the performance of those shocks could only be as good or better.
- The lack of adjustable damping bugs me, because I like toys. But like anything adjustable, the odds are once set it's forgotten. So I'm assuming the Basis are designed as a middle-ground between harsh and soft.
- With aftermarket sways, both upper and lower bracing, and sticky-wide PSS, the car already handles extraordinarily well. Using Tein CO's should only contribute to that. We'll see.
- I can always upgrade in the future and sell these as half-price. Just like my Swift springs, which I could easily sell here for half of what I paid.
