Vendor CZP Lightweight 2pc Rotors for Akebono Sport Brakes - 22lbs!!
CZP G37 Sport 2 Piece Front Rotors
CZP G37 Sport 2 Piece Front Rotors - $595.95
_________________________
We weren't satisfied with the rotors out there available for the 370Z Akebono (Sport) brakes, so we made our own! DBA's rotors came close and were a great starting point; our kit uses DBA slotted rotors with their "Kangaroo-Paw" ventilation, which has shown to run 20% cooler than traditional straight vanes. We then added our own aerospace-grade 6061 aluminum top-hats, which are much lighter than other hats, and help reduce heat.
The result is a super lightweight rotor, in at only 22lbs, which helps reduce unsprung weight and braking performance in one affordable package! For comparison, stock rotors are 30lbs each! These rotors are for use with the G37 Sport model with Akebono calipers.
No 2pc available, the parking brake assembly makes it a little tricky, but we do have both Stoptech and DBA, and either will go great with the above kit:
Stoptech Rear Pair (Slotted)
DBA Rear Pair (Slotted)
