Brakes & Suspension Reviews on brakes & suspension for G vehicles.
Air suspension power issues
Old 12-19-2016, 02:01 PM
slowguy27
slowguy27's Avatar
I have a question for the bagged riders or anyone that has experience with a bagged vehicle. Purchase an Airlift 3P system and running dual 380c compressors. Install went fine but a week or so later the fuse to the main pump/ harness kept blowing. Then I got a low voltage message alert from the system. apparently the compressor are pulling way more power than it stated it was going to and the alternator isn't charging the battery quick enough. So my question is has anyone else experience this issue with their system and if so what was the fix for it?
Thanks in advance.
seb123 (02-17-2022)
Old 01-06-2017, 06:29 PM
etphonehome22
etphonehome22's Avatar
I've dealt with a few air systems between my friends and I, and I've never heard of that. However I could see it being an issue with the wiring harness. Question 1, are you using the dual compressor harness? Question 2, what fuse box did you tap into?
Old 02-17-2022, 11:02 PM
seb123
seb123's Avatar
Any way you fixed this issue ?
Thanks in advance.
hi I know this post is a few years ago but did you find any solution to this issue. I just ended up unplugging my secondary harness.
audiRS4ever
04-17-2018 06:20 PM
slowguy27
12-19-2016 01:56 PM
*ICE*
General Tech Questions
11-30-2015 05:39 PM
Used2BaHEMI
03-03-2015 12:08 AM
awightguy
05-07-2013 11:33 PM
Quick Reply: Air suspension power issues
