Akebono front & rear caliper templates
Old 08-26-2014, 04:47 PM
Received 4,941 Likes on 4,174 Posts
Use this to determine if your wheels or the wheels you plan to get will clear the big front Akebono sport calipers. The rear template is also included but if they'll clear the front they'll clear the rear.
https://conceptzperformance.com/imag...nttemplate.pdf
https://conceptzperformance.com/imag...artemplate.pdf
The following 2 users liked this post by blnewt:
canuckcoupe (12-14-2020), Mad A (04-28-2017)
Old 08-26-2014, 05:41 PM
Ryne
The Steering Wheel Guy
Ryne's Avatar
For what it's worth, I think the template is a bit conservative (probably a good thing). I used the template to determine if my 2013 stock 18" coupe wheels would fit, and the template indicated they would not clear. This proved to be wrong as the calipers were realized to have adequate clearance, although not much.
Old 08-26-2014, 09:07 PM
I'd imagine there's a bit of wiggle room in template to allow for a small error in placement and scale.
I wanted to link this up since CZP no longer has their templates online
Old 06-30-2018, 04:24 AM
rattu93
rattu93's Avatar
Hey, I'm trying to see is my stock G37 18s can house the G37s akebono brakes, is that what you're saying you did & they fit?
Old 03-01-2019, 09:08 PM
PNW_IPL
PNW_IPL's Avatar
Can someone help me figure out how to properly scale the template?
Old 03-01-2019, 09:46 PM
That 1" guide in the lower right corner, use your custom zoom w/ your printer settings until you get that matched up to a true 1", shouldn't take much work IIRC.
Old 02-07-2021, 02:43 PM
Dixmagoo
Dixmagoo's Avatar
I am installing an after market set of rims on my 2010 G37 Journey and think I understand from reading this site, no fitment issue with adding Akebono front and rear calipers. Wheels are 9.5”x19” and 11x19, both with 22mm off set. Would y’all agree there would be no fitment issues here?
Also, other then new brake pad for the Akebono calipers, these Akebobo calipers will bolt right up without additional hardware and have no know issues with the 330mm rotors?
Notfelix
04-18-2019 03:29 PM
GLodi_31
07-24-2018 09:01 AM
TastefullyDoneG
12-11-2015 04:29 PM
Ryno23
36
06-04-2014 10:14 PM
Quick Reply: Akebono front & rear caliper templates
