Notices
Cup holder will not stay closed . . .
Old 10-02-2016, 04:17 PM
hobbs
hobbs's Avatar
Been acting funny the last few weeks. Today it will not stay closed at all. What and how do I disassemble and replace?
Old 10-02-2016, 05:39 PM
Epiphany
Epiphany's Avatar
Check that the insert that sits at the back of the cup holder is in place and not keeping the lid from shutting fully.
Old 10-02-2016, 11:25 PM
hobbs
hobbs's Avatar
It shuts fine, but will not stay closed. Looks like I need to pull the center console. Might try the magnets first.
Old 10-03-2016, 05:04 AM
Elco
Elco's Avatar
remove the center console, remove the cup holder from the console and fix it. Once you will get it out, is easy to figure out how to fix it.
Old 10-05-2016, 01:19 AM
hobbs
hobbs's Avatar
Link for instructions on how to R&R the console? Dealer says $400+ to fix it.
Old 10-05-2016, 02:16 AM
Elco
Elco's Avatar
Check the attacked file. You will find instructions to remove the central console there. Once console removed, you can remove the cup holder from console.
Don't rush, take your time, work carefully.
If you need to fix glue any pieces in place, use poxipol. NOT super glue or some other acrylic glue.
File Type: pdf
Old 10-15-2016, 06:19 PM
hobbs
hobbs's Avatar
Fixed!
1/4" washer cut in half, 3/4" Super Magnet and JB Weld.
Old 10-16-2016, 06:23 AM
Elco
Elco's Avatar
naaah... i fixed mine after a passenger broke it by pulling the lid open.
I disassembled the central console and i found a broken plastic pin on the latching mechanism.
I used a 3mm screw to put the pin back in place.
It was easy since the pin already had a hole and the screw fit perfectly.
It was a 20 minute job.
Taking the central console apart and put it back toke most of the time.
You have to disassemble the console to pieces to take the cup holder out.
Old 01-12-2017, 02:33 PM
Kmad55
Kmad55's Avatar
My 2009 G37X sedan cupholder piece broke..Any after market foam or rubber insert I could put in there to hold cups steady. The lid is short and no bother stays open.... If you know of an after market piece for sale instead of glue and tape and foam please email me.. Thanks Ken Kmad55@comcast.net
Old 02-01-2017, 08:12 PM
tank99
tank99's Avatar
I have to slam mine pretty hard to get it stay closed. I open it by pulling on it which produces a pretty loud plastic cracking noise...thought this was normal?
Old 02-01-2017, 08:23 PM
hurleyguys
hurleyguys's Avatar
def not normal. take your dash apart and fix the cup holder.
Old 02-02-2017, 12:09 AM
hobbs
hobbs's Avatar
Or see post #7. Much easier than disassembling console.
It will break soon and not stay closed.
Old 02-12-2017, 09:38 PM
tank99
tank99's Avatar
I almost always have it open anyway. If I do start to close it i'll look into the fix. Thanks for the responses!
Old 07-11-2018, 07:26 PM
hobbs
hobbs's Avatar
Pics of the fix to answer a PM. Note to self; red wine and glue do not mix! 1/2 cad plated washer and (2) super magnets from home depot. As long as I am posting pics; one from my vacation too.
Old 07-11-2018, 07:39 PM
Surfnazi
Surfnazi's Avatar
Mine did that dealer changed under warranty something got jammed up in the hinge that made it stick open and would almost have to snap it to close then it would not stay closed
Quick Reply: Cup holder will not stay closed . . .
