USB to bluetooth audio adapter
#91
What are these newer adapters that you've found? I have the Naxa-NAB4003, looking for a better solution other that the GROM box, I don't want to give up XM, and I'm am not going FM modulated in any shape or form.
I have a 2012 G37X non-nav. Galaxy S5 running Marshmallow 6.0.1
#92
I do! Works flawlessly in my 2011 sedan non-nav with USB only (no RCA or 3.5mm inputs in console). Android does not send song info to screen, but steering controls work. Also, phone stays connected to the car for phone calls, and to the Bovee adapter for A2DP streaming. I use Google Play Music, no problems at all. Music stops when car turns off, restarts quickly when car restarts. I'm impressed with the value.
Doesn't look like the WMA2000 is available anywhere... boo
#94
#95
FWIW I am using the WMA1000 bluetooth adapter in my '09 sedan with nav & ipod cable. Have had it for about a year to this date and have not run into any issues ever. I can stream Spotify to the head unit with song info and everything displayed on the screen, as well as change songs through the steering wheel. This is with an iPhone 6, with the latest iOS software update.
When I was doing research people were saying to get the WMA1000 not the WMA2000 or other models for the G37 at least.
#96
#97
#98
I did a lot of research and found no great options, so I wanted to let others know this might work well for them. Sure its $100, but for how well it works and how little work it is to install and tuck away, its certainly worth it.
#99
Sorry to dig up an old thread, but wanted to let others know that I just installed this device into my 2013 G37X w/o Nav and it works brilliantly. Two minutes to install and setup, no lag, steering wheel controls work, great quality, and works with music on the phone or streaming. I use Spotify. Also, the car's BT still works, so calls can be taken while listening and the music automatically pauses.
#100
WMA2000 Not working in my 2013 non nav sedan. It just says "reading device" forever. My iPhone (6S) is connected to it though and when I disconnect it from bluetooth it then stops reading the device and says please connect iPod (or whatever the terminology is). Reconnect to it via Bluetooth and it is stuck on reading device again. Also tried with an iPad and got the same results.
#101
Hmmm... seems odd that a piece of hardware designed for iOS would not work with iOS, but does work nearly perfectly with Android 7.0
Sorry to hear its not working well for you. I was just ecstatic to have a solution after so much digging. It was sort of a stab in the dark after I read a post in this thread that someone else had success with it.
#102
I think this is an iOS issue. There has been some talk about newer iPhones/iOS versions not working with even the factory bluetooth system.
Which is weird because my iPhone 6 with the latest iOS update still works with the WMA1000.
#103
#104
MYG37.COM Sponsor
Thank you for ordering GROM Audio product! Just so you know we are here to help you with any questions about GROM Audio USB and Bluetooth car kits for Infiniti.
#105
https://viseeousa.myshopify.com/prod...u_uBoCUvbw_wcB
braboftw (05-31-2017)
