Stealth install, almost finished
Old 11-06-2008, 03:29 PM
fcarpio
fcarpio's Avatar
Here is what I got (so far):
Just a trunk, right?
Remove the top trunk mat:
Remove the inner mat and now we got something
They are a DLS A4 for the tweeters and mids (4 ch), a DLS A3 (dual mono) for the mid bass, and a DLS A6 (mono) for the subs. No rear fill!
An AudioControl LC8 LOC hooked up to the factory head unit
A closer look
The processor, an Alpine PXA-H701 is tucked in there
But were are the subs? I actually have 4 x 10's stashed in the side panel on both sides of the rear sit. That is one on one side, but there is another one just below it
A detail of how the two subs are laid out on each side. Sorry for the picture buy I did not want to remove the side panel. I have posted pictures of the side panel on here before, you should be able to find them
A close up of one of the four subs, a DLS OA10. Yeah, I messed up the outter seal but I do not need it in this setup.
The speakers are a set of Hybrid Audio Technology Legatia L831 that are hidden in the doors for a factory look. I may remove the panel and take some pictures later. I did not feel like doing all that today
Like I said, I kept the factory head unit for the stealth look
This is the sunglass compartment. Eventualy I will replace all the interior (beige) upholstery to black upholstery. I kind of started with the sunglass compartment just to test the plastic dye. If it holds I will do the whole thing.
But when you open it you have this beauty, this is te RUX-C701 that controls my processor
Those are all the pictures for now. I still have some stuff left to do and the job is not finished yet.
Yes, it sounds very nice but it still needs some fine tuning.
Enjoy!
FC
Old 11-06-2008, 03:32 PM
nogoodname
nogoodname's Avatar
awesomeness
Old 11-06-2008, 03:33 PM
MaxToTheG37
Super Moderator w/ Boost
MaxToTheG37's Avatar
Holy Houdini batman....
looks great... im like...wtf when i see those 10s... hows it sound?
Old 11-06-2008, 03:46 PM
fcarpio
fcarpio's Avatar
It sounds nice, the bass drops quite a bit. As you can see in the processor picture I am only using the subs for 50Hz and below. The Legatia's mid bass is an 8" and puts out some really nice midbass. Since I am runing active I have to do a lot of tweaking, such as crossover points, eq per speaker, that is 5 (tweets and mids go together for two channels, midbass for two more channels, and sub single channel) different eq settings per channel with 31 channels each.
Old 11-06-2008, 04:02 PM
DdotRoq
DdotRoq's Avatar
Attempting to permanently brain damage your rear passengers, i see..
Your post receives Ddot's stamp of approval.
Old 11-06-2008, 04:16 PM
fcarpio
fcarpio's Avatar
Hehehe, my friends are already brain damaged.
Old 11-06-2008, 04:22 PM
aznutx
aznutx's Avatar
great work!
and quite creative.
Old 11-06-2008, 04:24 PM
oOmikeyboy
oOmikeyboy's Avatar
The thing in the sunglass holder is very creative. nice work
Old 11-06-2008, 04:29 PM
G37RacerX
G37RacerX's Avatar
Pretty frikken trick, love the stealth approach...
Old 11-06-2008, 04:41 PM
Gamedog
Sam Rothstein
Gamedog's Avatar
Wow... Very creative... Sound Clips NAO!
Old 11-06-2008, 04:51 PM
fcarpio
fcarpio's Avatar
I may do a 5Hz excursion test video and post it here just to show off.
Old 11-06-2008, 05:00 PM
Graham
Graham's Avatar
Looks very clean, if you get back in there, spray some black on the wood just so you can see any of the wood from the odd angles.
Old 11-06-2008, 05:06 PM
tfmbigdog99
tfmbigdog99's Avatar
Location: Where the kids are high and the grades are low. NYC
Looks pretty sick bra.
Old 11-06-2008, 05:08 PM
fcarpio
fcarpio's Avatar
There is MDF in the baffle, topped with a sheet of aluminum. If you search here you may find the older pictures before it was painted. Anyway, the whole thing is going to be covered with a panel. In the end, nothing is going to show.
aliiin
BMW Defector
aliiin's Avatar
nice setup!
Quick Reply: Stealth install, almost finished
