MyG37
MyG37 (https://www.myg37.com/forums/)
-   Wheels & Tires (https://www.myg37.com/forums/wheels-and-tires-307/)
-   -   Help At wit's end trying to get tires balanced/smooth (https://www.myg37.com/forums/wheels-and-tires/284456-at-wits-end-trying-to-get-tires-balanced-smooth.html)
derekjl Aug 30, 2017 01:08 AM
Been having tire/wheel vibrations ever since getting all season Dunlops installed about 10k miles ago. Buying the Dunlops might have been my first mistake as I was going to originally get Michelins, but they were 2x the price. The dealership installed them, knew within 5 minutes something was up, vibrations in the steering wheel, seat, etc. Took it to another place, they redid them from scratch, vibrations are about 50% better, not good enough. I then took the car to a place with the newest Road Force Elite balancer, they said all were within Road Force spec of 20 pounds, two I believe were at 3 and 6 pounds of Road Force, but two were also 3/4 of an ounce out of balance. Paid and left the shop, vibration is better, still there. I'm also now getting that "wop wop wop" sound at certain speeds. I do know with 100% certainty that it is the tires, this did not happen at all with the factory Goodyear RS-A tires as they were smooth as silk from 0-130mph. I've heard various opinions about Road Force balancing and what the numbers should be below, some people say 20 pounds others say below 10 pounds. Is there a some kind of definitive answer to this, or should I just assume the tires are crappy and that's as good as they will get?
Surfnazi Aug 30, 2017 06:20 AM
Tire might have heavy spot
blnewt Aug 30, 2017 08:49 AM
After 10k miles and all that balancing you've had done, and still having issues, it would seem that the tires are the culprit, may have had a bad manufacturing run, it happens.
I would take all your receipts for all the tire work you've had and go back to the place that sold them to you, maybe they can get you some pro-rated deals on a new set.
© 2026 MH Sub I, LLC dba Internet Brands
