Special R2C Performance Intake Group Buy!!!
Old Jul 22, 2009 | 12:33 PM
ImportPartsPro's Avatar
ImportPartsPro
Arrow R2C Performance Intake Group Buy!!!
A little about R2C Performance:
R2C has broken the barrier between achieving extremely high filtration efficiency while keeping filter restriction as low as the leading low restriction air filters. R2C has tested nearly every filter configuration currently available. That includes the most common cotton gauze filters from many different manufacturers, as well as cellulose (paper), and the various blended and "nano-fiber" products.
What they found was that low restriction invariably resulted in low filtering efficiency and high efficiency came with high restriction. Dust holding capacity (the measurement that determines how fast filter restriction rises when in use) on none of the existing products were up to our standards.
R2C's PowerFlow Performance Air Filter products were developed by the same people that designed and built many of the military's vehicles engine air intake systems and filters. The same obsessive attention to detail and engineering standards that has gone into those military products have been put into every PowerFlow filter you buy. The first thing to remember about an air filter is what it's designed for, and that's to protect your engine from damaging particulate. If it doesn't do that it shouldn't be on your vehicle ... no matter how low the restriction is.
Cotton gauze filters currently make up the majority of the low restriction air filters. When efficiency is addressed by these manufacturers, you usually find some qualifier with their claims such as "adequate for engine protection" and "meets manufacturers' requirements." There's a reason for those ambiguous statements ... cotton gauze filters aren't very efficient!
What the experts REALLY say.
Engineers from many vehicle manufacturers have addressed engine intake air filter efficiency in multiple presentations and papers to the SAE. The efficiency requirement that consistently comes up is a minimum of 98% initial efficiency with PTI Fine test dust. Other than our PowerFlow Filters not a single product sold as "low restriction" met that recommendation. Not one!
The PowerFlow Filters easily achieved that mark and then a whole lot more. R2C Performance produces the only low restriction filter to achieve the experts recommended engine protection requirements for engine intake air filters.
That means that a lot of people that have substantial investments in their cars and trucks are driving their vehicles to an early grave using a low restriction air filter, and on their way to the car graveyard they get steadily declining performance because their engines are not being protected from excessive wear by the part that was meant to protect it. You could say they are loving their cars to death.
How R2C Performance does it.
Testing, testing, testing ... and then some more testing. R2C tested everything. Media, pleat shape, pleat depth, pleat support etc. They didn't do simple flow testing either. They did complete SAE/ISO test procedures using SAE J726 and ISO 5011 test protocols in their own laboratory where they have two complete test stands. R2C tested everything on the market and they tested the same filter size and shape at the same flow rates and dust feed rates using PTI Fine test dust so that no variable that could influence the test results would exist and when they found that nothing currently on the market met their performance criteria they went to work developing a completely new product.
Changing the tests methods, the filter sizes, the air flow test rates and the test dust is often used to confuse or mask poor test result comparisons. If you read the other filter web sites if they discuss testing at all you'll notice that they either don't disclose the testing procedure or with close inspection you'll find that comparative test aren't on the same filter sizes or some other variable has been changed. R2c has been building and testing filters for a lot of years and we know that any variable in a test affects the outcome.
There is nothing else like the PowerFlow Filter. It is a high loft, all synthetic fiber designed specifically for engine intake air filters. Unlike organic materials (cotton and cellulose) our synthetic fibers stay stable over its entire life. It doesn't shrink or degrade with time and exposure to harsh atmospheric environments. Since the fibers are synthetic R2C can change the fiber size and shape to maximize efficiency and minimize restriction, so you get extraordinary efficiency and extremely low restriction. The high loft of R2C's filter media gives us exceptional dust holding capacity. In fact, R2C Filters have almost 3x more capacity at the same filter restriction increases than their nearest competitor. For you, that means our restriction stays lower longer, keeping your engine at its peak output longer than any other filter available to you. In use a low restriction filter with very little dust capacity doesn't stay a low restriction filter for long.
To clean the R2C filter, you just remove it from the vehicle, and blow some low pressure air from the clean side to remove the loose dust and then reinstall it. Your vehicle won't be out of service for a day while your filter dries and you won't have to worry about putting too much or too little oil back on.
So as you can see R2C Performance has produced a Dry air filter that filters better then the normal oiled cotton gauge filters on the market today
I am doing a Group buy on all the R2C Intakes for the G37's
G37 R2C Performance MaxxFlow Cold Air Intake System - Normally sells for $499(PM For GB price)
The G35 Sedan/G37 intake system is also available in Bright Nickel, Black powder coat, and Black chrome finishes for an additional cost(PM Me for details)
For the Group Buy prices please PM me.
Old Jul 22, 2009 | 12:44 PM
TheDuke's Avatar
TheDuke
Count me in!
Old Jul 22, 2009 | 12:52 PM
shumby's Avatar
shumby
wowo could not come at a better time. Just got the ok from the wife to get these. Will you ship to canada? please PM price with shipping to T9E 0K9
Old Jul 22, 2009 | 01:45 PM
shumby's Avatar
shumby
Bump back to the top.
Old Jul 22, 2009 | 02:09 PM
Blackjack's Avatar
Blackjack
PM shipped to 30114
Old Jul 22, 2009 | 02:13 PM
shumby's Avatar
shumby
ata boy BJ
Old Jul 22, 2009 | 02:18 PM
jran76's Avatar
jran76
Can you PM me the GB price shipped to 75093. I would like the price for whatever the regular finish is, and black.... Thanks.
Old Jul 22, 2009 | 02:51 PM
ImportPartsPro
PM's sent
Old Jul 22, 2009 | 03:24 PM
Triple_X's Avatar
Triple_X
price shipped to 01960.. for group buy
Old Jul 22, 2009 | 03:42 PM
ImportPartsPro
PM's sent
Old Jul 23, 2009 | 03:36 AM
shumby's Avatar
shumby
bump to the top.
Old Jul 23, 2009 | 07:14 AM
shumby's Avatar
shumby
bump again
Old Jul 23, 2009 | 09:34 AM
wrathletik1's Avatar
wrathletik1
pm me for group buy price to 91214 california
Old Jul 23, 2009 | 09:54 AM
shumby's Avatar
shumby
And another bump to the top for the morning readers
Old Jul 23, 2009 | 11:18 AM
ImportPartsPro
PM's sent
