G37xS Sedan, Black on Black with Tech
Old Jun 10, 2025 | 01:16 AM
neilg37xs's Avatar
neilg37xs
Sold- 2012 G37xS Sedan with Tech Pkg
Year: 2012
Make: INFINITI
Model: G37x Sedan
Price: $7000
Mileage: 168500
Color: Black
Location (State/Prov): MN
Hi, Selling my G as I need more space
Options/packages
- Sport package: (sport seats with thigh and side air bolsters, driver and passenger manual thigh extensions, perforated leather, sport front bummper, sport steering wheel with electric gauge tilt (love this feature so much, will be missed)
- Tech package: radar intelligent cruise control with distance adjustment, (not start and stop) electronic pretensioning seat belts, rain sensing wipers
- Illuminated driver and passenger door sill plates
- Mud guards
Mods (all done more than 6 years ago, no issues)
- Windows tinted, with 50% ceramic formula one Lunna (sp?) amazing difference in heat rejection! (50% is legal limit for MN)
- Ambient lighting (official Infiniti parts)
- Swapped in Sport Grill, Black lines instead of chrome.
- DRLs (official Infiniti parts)
- LED projector fog lights (Direct replacement from Morimoto)
- Interior lighting bulbs switch out to LED from SuperBright LEDs (all same color temp a cool white)
- Reverse light LED upgrade from SuperBright LEDs (Brighter than the filament)
- Front Blinkers change over to a dual LED parking light and blinker switch bulb, 8 years ago still works great! (with secured resistors)
- Rear blinkers upgraded to LED (with secured resistors)
- Front amber side makers switched to LED bulbs
- Aries 3D floor mats front and rear (with original cloth mats underneath)
- Weather tech trunk liner (with original cloth mat underneath)
- Remote start module, hit lock button 3 times on factory remote and car starts runs for 15-20 min, 3 times again and turns off, was all plug and play connectors.
- Chrome climate and audio *****
- Ground wiring kit, black color, doesn't stand out. I know some think it placebo but I swear the auto trans shifted quicker/better after haha
- Rubber Infiniti trunk organizer, from a 94 G20 but it's the best one I have ever used! its solid, can still have fun with the turns even with groceries in the back
Maintenance/repairs done:
- I am the second owner, bought back in 2015 after it was traded in at a dealer
- Solid maintenance record, battery replaced several years ago, oil always changed on time if not just a few miles past, at the dealer. Last 6 years or so have done full synthetic
- Last two years I have been doing every other oil change myself to just save a little money and I enjoy working on it.
- Replaced the radiator myself, along with top front hose, bought it on rock auto, after getting a hole in it due to a chunk of some fabric causing it to corroded and make a hole in the corner :| not even a hole from a rock.... had the dealer recharge the AC for me after
- Front brakes: did the front pads ceramic and rotors myself 10-20k miles ago, flushed brake fluid, drivers side hub also replaced was starting to make some noise.
- Rear brake pads, also ceramic, a while ago go, dealer said rear pads are at about half life.
- Just last month had the fluids for the transmission and transaxles flushed and filled.
- Tires always done through Discount Tire and should still be under warranty, I do a little bit bigger sidewall for smoother ride, speedo only impacted by 2-3 MPH
- Exhaust Y welded as a crack formed at the connection point, was nice and loud sounded great but I was "that" neighbor for too long, and was too intense in the underground ramp at work ha!
Likely future maintenance that will come up:
- CV boots are showing evidence of some slow leak but never see anything on the garage floor
- R&P steering boots same thing, no leaks on the garage floor and fluid level unchanged
- Last month Dealer said front sway bar is lose and recommended replacement, its cheap and easy so may do it myself after I take a look at it.
- Last month Dealer said there is a little play in the ball joints but not a safety concern.
- Alignment: Very slight almost not even noticeable pull to the right, Dealer confirmed with their drive in scanner, but no uneven tread ware, and I even missed a rotation to see and no noticeable difference, dealer confirmed as well with their drive in scanner.
- Struts? I have never replaced them, which has surprised me, but work great still
What doesn't work
- LED light in dash clock
- Cup holder cover does not stay closed, I never close it anyway
Exterior condition
- a few digs here and there and paint chips touched up
- Rear bumper was damaged by a driver tapping me in line for a stop light, so was replaced, but then a few months later, even with a back up camera and rear park sensors I managed to scrape an area on the rear bumper against a small cement base of a light pole, no color transfer, few scrape lines in the plastic
- Front bumper has a bit of pitting given the age and miles
- Windshield has 2 chips that were glued/sealed
- One wheels has a small curb rash marks but that's it, some scuffing around the lug nut openings, but no corrosion
- No visible rust on the body panels or doors
- crystal clear headlights, fog lights and DRLs
Interior Condition
- Steering wheel has some visual wearing of the leather but no tears or fraying
- Left side of the drivers seat has some ware winkles in the leather but no tears or splitting
- Just a few scuffs in the back seat, no major tears or holes
- Very clean! only some salt crust on the edge of the drivers cloth mat that is under the Aries 3D mat from the pervious owner.
Overall well taken care of for age and miles, washed frequently in the winter, still drives great! Always garaged at home, and for the last 8 years garaged at work as well.
Long post but I like to be transparent even more so with this community since I have learned so much from this site. I'm also going to miss this car! Posting here first.
PM me if interested
Thanks
Neil
[img alt="Infiniti windshield sun visor, rear window could up sun visor, Infiniti G20 trunk organizer that’s great, tub of parts, all
Manual documents, discount tire current tire documents, window tint warranty documents, certificate of 50% tint (legal limit in MN) neck pillow if ya want them ha"]https://cimg9.ibsrv.net/gimg/www.myg37.com-vbulletin/2000x1504/img_1240_4ef25fb9f81eaa5ddcbb719142e3e7161458c245. jpeg[/img]
Infiniti windshield sun visor, rear window could up sun visor, Infiniti G20 trunk organizer that’s great, tub of parts, all Manual documents, discount tire current tire documents, window tint warranty documents, certificate of 50% tint (legal limit in MN) neck pillow if ya want them ha
Reverse LED bulb upgrade
Rear bumper scrapes
Rear bumper scrapes
Clear lenses, pic of the pitting in the front bumper
Old Jun 30, 2025 | 06:57 PM
ageiger68's Avatar
ageiger68
I meant to send this as a DM! Was obviously rushing too much.
I want your car!
Old Jul 2, 2025 | 12:06 AM
ageiger68's Avatar
ageiger68
Purchase of your car--sent a PM but haven't heard back yet.
Hello,
I sent a PM (I think I did it right) about buying your vehicle. Did you get it? Please let me know so I can figure out what I did wrong if you did not receive it.
Thanks so much,
Anne G.
josephwhan
Jun 24, 2024 08:48 PM
doublea88
Apr 8, 2019 10:14 AM
daviper
May 19, 2016 11:55 AM
Aug 21, 2013 04:55 PM
