Griot's Garage Random Orbital DA Polisher
Old Jun 22, 2010 | 04:21 PM
slimshady523's Avatar
slimshady523
Griot's Garage Random Orbital DA Polisher with polishes/sealant/pads/case
Price: $100
Location (State/Prov): MD
I have a Griot's Garage Random Orbital DA Polisher that I don't need anymore. Please see my eBay auction if interested, bidding starts at $100:
Griot's Garage 6" Random Orbital Polisher with extras: eBay Motors (item 290447727307 end time Jul-02-10 1217 PDT)
Includes organizer bag, instructional DVD, brand new unopened Machine Polish 3 and One-Step Sealant and red waxing pad plus opened Machine Polish 1 (full), Machine Polish 2 (1/4 full), Machine Polish 3 (3/4 full) and 3 orange polishing pads (used but washed and in good condition).
Attached Thumbnails Griot's Garage Random Orbital DA Polisher-griot-s-polisher-1-web-.jpg
Old Jun 22, 2010 | 04:23 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
just FYI this will probably be deleted or moved to the private classifieds by the mods. GLWS!
Old Jun 22, 2010 | 05:49 PM
I don't think people even look at what forum they are posting in anymore, they just pick one and drop it there whether it's the right one or not. Moved.
Free bump.
Old Jun 22, 2010 | 05:59 PM
slimshady523
Sorry, thanks!
Old Jun 22, 2010 | 06:04 PM
RaulGCustom's Avatar
RaulGCustom
SoCal Driven
PM Sent to you
Old Jun 22, 2010 | 06:22 PM
slimshady523
Replied, thank you.
Old Jun 22, 2010 | 07:14 PM
RaulGCustom
SoCal Driven
Griot's re-engineered polisher has more power to remove more imperfections!
Griot's Garage 6 inch Random Orbital Polisher has been re-engineered and is now more powerful and better than ever. It now has a powerful 7 amp, 850 watt motor with improved low-end torque for low speed polishing. A wider, 5/16" diameter orbit provides faster polishing. Get smooth, flawless results in less time with Griot's Garage 6 inch Random Orbital Polisher.
Griot's Garage has actually improved upon their orbital buffer design! The Griot's Garage 6 inch Random Orbital Polisher outperforms other dual action polishers because it has a stronger motor capable of producing higher speeds. This buffer operates at 2,500 to 6,800 RPM and has a wider 5/16 inch orbit than its predecessor. The enhanced speed combined with a wider orbit enable the pad to make faster, broader passes over the paint. Imperfections are removed more quickly and completely.
The Griot's Garage 6 inch Random Orbital Polisher also boasts more torque, which keeps the pad moving even under pressure. Commonly the pad will stop rotating on a typical DA polisher when pressure is applied. Griot's Garage 6 inch Random Orbital Polisher is designed to keep moving so imperfections are eliminated faster.
Griot's Garage Random Orbital Machine has a fully adjustable bale handle.
The polisher has also undergone some smart exterior design changes. The housing above the backing plate is now smaller, which gives the polisher a more streamlined appearance and you'll have a better view of the pad. Griot's Garage 6 inch Random Orbital Polisher has a longer 10 ft. cord. The bale handle is fully adjustable for maximum comfort while detailing.
Griot's Garage Random Orbital Machine has a wider orbit for faster swirl removal.
Griot's Garage 6 inch Random Orbital Polisher includes a backing plate. Use Griot's Garage 6 Inch Red and Orange Foam Pads to quickly remove swirls, scratches, oxidation, water spots, and then apply a glossy coat of wax.
While the polisher is more powerful and faster than ever before, Griot's Garage 6 inch Random Orbital Polisher is still very safe on your vehicle's paint. The random orbit motion of the pad prevents heat from building up in one spot. Less heat is produced by the polisher.
Griot's Garage 6 inch Random Orbital Polisher is lightweight and simple to use, even for an inexperienced user.
Restore the shine to your vehicle with the more powerful, faster Griot's Garage 6 inch Random Orbital Polisher!
Apply the washer to the backing plate post.
Screw the backing plate onto the polisher.
Tighten the backing plate onto the polisher with the included wrench.
Press the 6.5 inch hook and loop pad onto the backing plate.
Features:
More Powerful 7-Amp, 850-Watt Motor
2,500 - 6,800 Orbits Per Minute
Variable Speed, Wider RPM Range
Wider 5/16" orbit pattern for faster and better results
Ergonomic Adjustable Handle
More Torque, Better Performance
Longer 10 Foot Power Cord
Backing plate included
Old Jun 22, 2010 | 07:19 PM
slimshady523
Mine is the previous version. I cannot find its exact specifications. Might still have the box at home, maybe they're on there.
stm37s
The M - Spot
14
Oct 23, 2015 01:56 AM
hamkha1ebay
Oct 3, 2015 02:55 PM
djdiskino
Sep 29, 2015 07:18 PM
VIVID
Sep 29, 2015 10:58 AM
