tires help with 19x8.5
just bought a square set up 19x8.5 +38 for my sedan. I know tires size I can use is 245/40r19 but are there any other sizes I can use without triggering the vdc or affecting the awd system. did a lot of searching but still drawing a blank. I am lowered on Tein H Tech springs for the 07-08 sedans. Any help is much appreciated and thanks in advance.
Here is some info posted by blnewt which I copied to a text file on my desktop. I refer to it constantly!
It's the variance in tire diameter front to back, there's plenty of staggered tires that will work but they need to be under 1% diameter variance, and the closer to zero the better FWIW Here's the best tire combos I'd recommend for 18s/19s/20s, then pick proper wheel widths/offsets to get them to fit~ 18s 235/45 & 265/40 (0.07%) 245/45 & 275/40 -0.07% 255/45 & 285/40 -0.22% 19s 235/40 & 265/35 -0.37% 235/40 & 275/35 0.67% 245/40 & 275/35 -0.52% 245/40 & 285/35 0.51% 20s 235/35 & 275/30 0.07% 245/35 & 285/30 -0.07% This calculator should be used when trying new setups~ https://www.myg37.com/forums/tire_rim_calculator.php SQUARED SETUP: 255/35-19 |
The charts posted above are good combos if you want to eventually get staggered width wheels.
For running a square setup on 19x8.5s the widest tires I'd recommend would be 255s, a 255/40/19 will be about 1/3" taller or a bit over 1% different from the OEM diameter for your car. For a square setup being a bit over 1% is ok. A 255/35/19 will be about 3/4" shorter and about 2.6 % different from oem, this may be a bit much, but ??? If you decide to run a staggered combo down the road you really need to be under 1% difference from front to back. |
thank you!
(Post 4116139)
Originally Posted by v36_g35x
(Post 4116148)
what size would give a minimal stretch but functional. I am trying to keep it square for now for tire rotations and what not.
https://cimg8.ibsrv.net/gimg/www.myg...6da0072f74.jpg
(Post 4116196)
225/45/19 would be a good fit, that's the factory size on the front OEM coupe sport wheels (19x8.5)
(Post 4126311)
well thanks for the help I went with 245/40r19 all around |
Looks nice and being able to do a full 4 wheel rotation will be a good plan!
(Post 4126335)
