Will wheels from an Accord fit a G37x?
Old Jul 25, 2011 | 05:07 PM
nbast's Avatar
nbast
I'm hoping to upgrade to a G37x coupe next year, and am trying to figure out if it would be a reasonable plan to use the summer wheels from my Accord as winter wheels for a G37x coupe?
They are 18" Sport Edition. How do I determine if the bolt pattern is the same and if I would need some sort of spacer?
I'm guessing that if I got the sport package there might be interferance with the larger brakes. Does that sound correct, or would the sport package brakes fit (assuming the wheels would fit the car at all)
Old Jul 25, 2011 | 05:22 PM
OB G's Avatar
OB G
I'm pretty sure the bolt pattern on Honda Accords are the same as our Gs. You need to know the offset too. Take off one of the wheels and look inside. It'll say the bolt pattern and the offset of the wheel. That'll give you a better idea of whether or not they will fit. As far as BBK, it might fit but you'll probably need spacers. IMO 18s look small on our car. I'd stick with the stockies over those.
Old Jul 25, 2011 | 06:02 PM
nbarone's Avatar
nbarone
Our bolt pattern is 5 x 114. Not sure what the Accord is,
Old Jul 25, 2011 | 08:53 PM
Ibanez540r's Avatar
Ibanez540r
Bolt patter is 100% the same, but as the above stated, it's the offset you have to check and watch for.
Old Jul 26, 2011 | 01:50 AM
LarryG's Avatar
LarryG
Why would you want to put Accord rims on the G anyways. In my opinion, 18 looks too small on the G.
Old Jul 26, 2011 | 02:08 AM
myk1013's Avatar
myk1013
He said to be used as winter wheels. Bolt patterns are the same. It's the offsets you gotta worry about. (akebono clearance).
Old Jul 26, 2011 | 04:04 AM
1NEETO's Avatar
1NEETO
The stock 19's barely clear the akebonos, I'm sure you're gonna need some very aggressive spacers.
Old Jul 26, 2011 | 01:10 PM
nbast's Avatar
nbast
Thanks for the information! I'll have to remember to check the wheels for offset numbers the next time I have them off.
And yes, this would be for snow tires, so smaller is generally better.
Now I just hope I can convince the wife that a smaller car is a good idea...
Mattlorentzoe
May 24, 2021 08:49 PM
JoshB
Oct 15, 2015 03:08 PM
james6980
Oct 9, 2015 01:28 PM
drkashifa
Aug 18, 2015 04:38 PM
gcruzjr78
Aug 18, 2015 10:15 AM
