Sedan wheel question 20"
Old Jul 21, 2011 | 11:10 PM
xclusive's Avatar
xclusive
Can anyone help me and tell me if these wheels will tuck in the rear 20x10 if I'm dropped already??????
20" NISSAN 350Z 370Z G35 G37 MUSTANG SC430 WHEELS RIMS | eBay
Old Jul 21, 2011 | 11:20 PM
rks's Avatar
rks
I 'think' they will still tuck in but it probably depends more on the offset. 18 and 20 might be too aggressive for the sedan but I could be totally incorrect. are you planning on negative camber or stretching your tires?
Old Jul 22, 2011 | 12:02 AM
jamesshifflett's Avatar
jamesshifflett
I didn't see the offsets listed but that will dictate if they tuck or not, along with Camber....so essentially what rks already said
Old Jul 22, 2011 | 12:09 AM
Vini's Avatar
Vini
I have those on my 2011 G37S sedan just make sure you get the right offset my front is 30 and the rears were shaven down to 42 I think.
Old Jul 22, 2011 | 09:04 AM
xclusive's Avatar
xclusive
Nice good idea so basically the way they come from factory they might rub but if I get them shaved a little they should have a little more clearance. Would it be too much to ask for some pictures of how they look please.
Old Jul 22, 2011 | 03:24 PM
rpm&my_G35's Avatar
rpm&my_G35
Do you have pics posted where we can see these wheels on the car?
Old Jul 22, 2011 | 06:31 PM
jran76's Avatar
jran76
With the listed offsets (+18 and +20) they will not fit without some work. By work, I mean stretched tires, negative camber, etc. The rear will poke out a lot, and you will need to run around -3 degrees of negative camber to even get close to tucking (maybe a little less depending on the tires).. The front won't be as bad, but will still need something done.
G's
Nov 5, 2023 12:01 PM
ModInJapan
Wheel & Tires
98
Aug 7, 2016 06:04 PM
SLEV3N
General Tech Questions
Oct 17, 2015 05:58 PM
james6980
Oct 9, 2015 01:28 PM
