Avant Garde M310 Mesh Deep Concave
Old Jul 5, 2011 | 01:53 PM
ANMVQ's Avatar
ANMVQ
Hi guys,
I'm looking at getting these and was wondering what kind of tire offset I can run on a X Coupe,. I know it's out here in theard but all the formulas confuse me, Maybe some with a X and a Staggered set up can Chime in.
Oh the wheels are 19x9.5 +20 and 19x11 +18. Thank you for any and all help.
Old Jul 5, 2011 | 02:02 PM
OB G's Avatar
OB G
can we run that wide and low of an offset wheel in the rear???
Old Jul 5, 2011 | 02:13 PM
Weiboy718's Avatar
Weiboy718
The rear is too aggressive.
Old Jul 5, 2011 | 02:21 PM
WPPJR30's Avatar
WPPJR30
The rear is too aggressive, unless you want to run a lot of negative camber.
Fixed.
Old Jul 5, 2011 | 02:33 PM
ANMVQ's Avatar
ANMVQ
HMM ok definitly not looking to run a camber kit. So what should i be running in the rear?
Old Jul 5, 2011 | 02:54 PM
ANMVQ's Avatar
ANMVQ
Vendor said no Camber kit but the tire options look a little big for a X no?
Options on tires are 245/285 set up or 255/305 setup. Is there something about 3%5 % rolling diamaiter??
Old Jul 5, 2011 | 03:14 PM
ANMVQ's Avatar
ANMVQ
OK never mind, He made a mistake and gave me 370Z tires, I'm gonna call him later on.
Old Jul 5, 2011 | 04:18 PM
jhenka's Avatar
jhenka
on an x the max size you can go without running neg camber or having rubbing issues is like 10" +28 maybe a tag bit more but then your risking rubbing.
Old Jul 5, 2011 | 07:28 PM
cardoza's Avatar
cardoza
Anything is possible!
Old Jul 6, 2011 | 01:02 PM
ANMVQ's Avatar
ANMVQ
Ok so the 19x11's are not going to work, I would have to buy coils, and dial in a neg camber. To much $$ for me, So here is what I was thinking,
19x8.5 +35 and a 19x9.5 +40 with 245/40/19 and 275/35/19 Tires?
BTW vendor is super helpful.
Old Jul 6, 2011 | 01:26 PM
jhenka's Avatar
jhenka
you might need a slight spacer in the front but that looks pretty good
Old Jul 6, 2011 | 02:04 PM
ANMVQ's Avatar
ANMVQ
Ok thanx, Slight, Like 5mm?
Old Jul 7, 2011 | 02:28 PM
ANMVQ's Avatar
ANMVQ
So found this on another forum, So i'm looking to maje sure the overal DIAM is less that a 5% difference?? So confused,
Stock Tire - 245/40R19
Section Width: 9.64 in 245 mm
Rim Diameter: 19 in 482.6 mm
Rim Width Range: 8 - 9.5 in
Overall Diameter: 26.71 in 678.43 mm
Sidewall Height: 3.85 in 97.79 mm
Radius: 13.35 in 339.09 mm
Circumference: 83.91 in 2131.3 mm
Revs per Mile: 778.7
Actual Speed: 60 mph 100 km/h
Speedometer Difference: -
Old Jul 7, 2011 | 02:43 PM
ANMVQ's Avatar
ANMVQ
Sorry for the jumble tried formating three times. :/
Better?
Search Tires Tire 1 - 275/35R19
Section Width: 10.82 in 275 mm
Rim Width Range: 9 - 11 in
Overall Diameter: 26.57 in 674.87 mm
Sidewall Height: 3.78 in 96.012 mm
Radius: 13.28 in 337.31 mm
Circumference: 83.47 in 2120.1 mm
Revs per Mile: 782.8
Speedometer1: 60.3 mph 100. km/h
Speedometer Difference: 0.526% too fast
Diameter Difference: 0.53%
Old Jul 8, 2011 | 12:17 AM
OB G's Avatar
OB G
check this out http://victorylanegarage.com/downloa...oze-041911.pdf. With 245/40 275/35 you're looking at ~.3% difference in OD so you'll be fine.
