Help Had new wheels and tpms sensors installed on a 2010 g37 coupe convertible.
It appears that it is stuck in learning mode, as I start the car the warning light flashes then after about a minute it goes solid. I read I need to set the inflation of the tires at different psi each with one of them at 26psi. Is this true? If not, what do I need to do?
Thanks. I actually found out that two of the new tires are bad (29 lbs of road force on the rears) and talked to Discount Tire today. They're going to do the reset for free since I'm buying tires from them too.
