Headlight issue 09 Sedan
I turned on my Auto headlight switch on my way home from work I noticed my dashboard dimmed indicating lights should be on.
I then turned them to the ON position again dash is dim and lights aren't on. Then I turned the switch all the way up and finally the lights come on. Also HI-beams works no problem when pulled back to engage. Where should I start? |
Update: I didn't check any fuses. Went outside and put my lights on Auto and they turned on. Then I switched it up to the headlights ON and they won't come on.
Switch maybe then
Originally Posted by Surfnazi
(Post 4118611)
Switch maybe then
Or that check with meter
