MyG37
MyG37 (https://www.myg37.com/forums/)
-   General Tech Questions (https://www.myg37.com/forums/general-tech-questions-315/)
-   -   Oil Filter Replacement Indicator Won't Go Away (https://www.myg37.com/forums/general-tech-questions/260273-oil-filter-replacement-indicator-wont-go-away.html)
Avedis Jul 29, 2014 06:42 PM
I have a 2012 G37x. I can't seem to get rid of the Oil Filter Maintenance indicator alert. It keeps coming on every time I start the car and I clear it.
I've tried resetting the oil filter maintence distance, changing the distance to a higher number, even turning off the alert. The indicator keeps coming on no matter what.
Any ideas what I can do?
telcoman Jul 30, 2014 02:34 AM
I believe the exact procedure is in the owners manual.
If that doesn't work call the dealer from a cell phone while inside your vehicle and have them walk you thru the reset procedure.
If that fails, bring it in to the dealer.
BTW I have gotten lazy with doing my own oil changes. I now let the dealer do them and they turn off the reminder prior to returning my vehicle.
You are under warranty
Good luck
Telcoman
Daddy Fat Sacs Jul 30, 2014 08:23 AM
U have to reset the all the maintenace from your cluster gague as well. So not only thru the the dash unit, but also with the 2 buttons near the sterring wheel. Done deal
Avedis Jul 30, 2014 02:48 PM
That was the answer Daddy Fat Sacs. Thanks for the help!
botlfed98 Jul 31, 2014 04:47 PM
is this something on the newer models? I don't recall ever seeing an oil filter light.
Daddy Fat Sacs Aug 1, 2014 09:12 AM
its not a light, its an indicator warning that pops up on our dash or head unit to remind you that your scheduled maint is due.
Avedis Aug 1, 2014 11:36 AM
It's rather odd that those with the Nav package have to deal with two separate maintenance alerts settings for the same thing. One in the Nav and the one in the instrument cluster. One would think that they would be sync'ed so you'd only have to mess with the Nav settings to deal with them.
Daddy Fat Sacs Aug 1, 2014 11:50 AM
actually both have to deal with it in terms of with or without nav. Every G has the dual maintenace settings, well at least all 10'+ do.
botlfed98 Aug 4, 2014 11:01 AM
I must have mine turned off on the nav cause I don't ever remember seeing anything
warped ideas Aug 4, 2014 12:14 PM
I found that two separate notifications for the same thing redundant. I just turned off the alerts in my instrument cluster. Funny thing is that it's been so long that I have forgotten how I did it.:dunno:
tjafar Jan 30, 2017 06:51 PM
oil engine and filter reminders
folks.
the only way i could turn the reminder off was to increase the setting to a large number.
the distance cannot be reset and i have tried and followed the procedure several times.
Will be visiting the dealer to learn or to complain depending on the advice i get there.
i could not get my homelink to connect to learn the garage door code, using the method in the manual
the tpms system reset listed here does not work either. i have an 09 g37xs.
blnewt Jan 30, 2017 07:23 PM
It's a clumsy interface but if you can increase the change interval you can also reset it.
Took me a couple tries to get it figured out, I'd go back and work through it. Once the area is blacked out you just push the reset button (IIRC it's the lower button).
dawginole May 30, 2019 11:52 AM
Thanks!! This fixed my problem as well.
Surfnazi Jul 23, 2019 12:57 PM
Turn off all maintenance reminders in navigation
© 2026 MH Sub I, LLC dba Internet Brands
