Cannot Pump a Full Tank?
The problem of not being able to get a full tank seems to be getting worse. After it clicked as if it were full the first time I pulled the trigger again, and set it, and did that about 3 or 4 times. When I got back in the car it still wasn’t a full tank, I manually pumped about 2-3 galllons myself. I have no idea what could be causing this and it happens with different gas stations and different pumps. They seemed to have fixed my Evap. Fuel Leak CEL but now I can't fill my car up all the way without risking gas splurging out back at me if I miss judge the amount that is already pumped.
Anyone have any thoughts or ideas about what this could be? |
Pump on slow.
They typically are on a slow pace, I've tried that, this morning it took me about 15 min to pump gas, where as at a fast pace I'm there for like 3-5 mins max. I thought I was going to be late because it was pumping so slow.
M last couple fillups have been similar. Once it gets around 3/4 full it keeps shutting off like it is full. Then I can only get it work if I pump the gas real slow. I really dont fill up past 3/4 most the time anyway but still kinda annoying.
Originally Posted by Kidcane
(Post 2581741)
so you gonna go for the lemons now Graham?
Graham-
My car did the same thing. I took it into the dealership and ended up getting the fuel tank replaced. There was a "device" in the neck of the fuel tank which was not functioning properly and would not allow you to fully fill the tank. (I forgot what the "device" was called, and my repair docs are nowhere near me at this time. I can check it out when I get home from work.) Once they put a new fuel tank in the car, I have never had a problem since. I would venture to guess that your gas tank has the same issue as mine did. |
Graham = Pencil Neck
Originally Posted by NotUrG
(Post 2581768)
Graham-
Originally Posted by elite
(Post 2581770)
Originally Posted by Graham
(Post 2581778)
Thanks for the info, I'll pass that along to the Service guys, but they don't listen very well. So hopefully tomorrow they'll call to tell me the entire gas tank is being replaced.
I'll make myself a note to look for that repair order when I get home and try to scan it in and email it to you so you can take it to the dealership tomorrow. |
(Post 2581784)
Even though I hate you, do you know where a PDF of this is. I'm going to print this off, but I enjoy shoving PDF print out of it in their faces.
Every file I found was corrupt. My search engine only finds weirdo pics. Good Luck! oh and I hate you too. But Luv yo mammies whispering eye! :icon17: |
(Post 2581793)
