Rough road clunk at low speed | 2009 G37x 125,000 miles
Thanks for the update!
Back to the drawing board 🙃
-Eric
-Eric
i have the same issue, right side- first i thought it was the sway bar bushing that may have worn out but no.
while i had the front sway bar out I also checked the end links they don't make any sounds either, they were firm.
I am just trying to replace each and every part like Guy from norcal did
If anybody has found a resolution please let me know.
I have a slight, faint rattle at low speed from the front passenger side as well. It occurs only at low speed and on uneven ground. I notice the sound more when going down an incline with uneven road as well.
I have replaced the front endlinks with new SPL endlinks for the G37xS coupe (previously had the Moog) and the sound rattle remains. The FA500 coilovers have been inspected and reseated and no problems found either. My hotchkis swaybars were greased recently as well. Otherwise, no other modifications to the G.
Anyone have any ideas on the noise?
G37xS-Life (05-27-2018)
-Eric
Well, the mechanic replaced both the strut mounts and the struts ($1,000), then said there was still a slight rattle suspected to be from the front end links, so we replaced those too.
I've now put about 400 miles on the car and there are still suspension clunks and rattles. Some gone, others still present, depending on the surface. Ride is certainly much better now.
Totally at a loss. Maybe I'm insane and the noises aren't from the suspension?
Too bad it's not fixed - for $1,000 and replacing the struts, mounts and end links, one would assume a quiet ride. 😕.
My rattles seem to be from underneath and I'm planning on getting a microphone close to record (audible with windows down), however the clunks I have are more of a solid clunking and easier to hear with the windows up.
-Eric
Yeah, I'm quite annoyed. This cannot be normal for this car. Wondering if I should try to test drive someone else's to verify. It makes noises like a late 90's GM car with 200k.
Well i replaced the lower control arm,And the clunk is still there. I have no clue WTF is making that sound. I know it is the right passenger side, And it sounds like it's in the fenderwell.
I drive over RR tracks when i get to work. I go slow, And at an angle. When the right front goes over the tracks i hear it.
I'm really starting to loose my mind.
#30
I've got clunking sound when making slow turn from dead stop or when slow accelerating, ( not always there )noise is coming from front suspension.
Also Ive noticed when I punch in on 3rd around 80 my front feels very odd, very poorly planted, and this is with 255 tire on the front.
I guess it is time for me to make suspension parts replacement list.
