The drop is supposed to be 1.2 inches front and rear for the Z. The drop for the my G35s is just over 2 inches. I am on stock struts for now and the ride is excellent. It's not bouncy at all. I just wanted to let everyone know the 350z springs work great on the sport.
Very nice, hope you're running full camber kits w/ that deep drop
Looks similar to my B&G spring drop, was a bit too low for my daily driving so went up a bit to zero gap and a bit less stress
Love those rims on your G too, nice choices all around.
What are you running now? I've been looking and debating between tanabe and swift. I'm looking for a mild drop that won't cause me to have to get a different camber kit.
Go with the Swifts.
I have no issues with camber or toe...camber maybe a slight off from stock, but no ill effect or uneven tire wear.
I just had my tires swapped over to my new rims and the tires are even across the width...still looking new with over 15K.
Go with the Swifts.
Well I was hoping to hear some good about tanabe since they're cheaper, but everyone seems to like their swifts so I guess I'll pony up the extra dough and go with them.
I'm running Megan LP coilovers, it's not a mild drop but compared to my B&G springs I have the height set milder for sure.
Looks good! I had found a set of 370 nismo springs that I thought about trying out on mine.
Do it, apparently they're all interchangeable from what I've read. This is the reason I bought these as I found a deal I couldnt pass up.
Originally Posted by Paratrooper
that looks amazing, the wheels really set this off!
Thank you, I think so
Originally Posted by Detail
That looks outstanding.
Thank you
None yet, but Im buying new tires and will need a kit. Any recommendations? Thank you, Black G's ftw! Yours is looking clean as well!
Originally Posted by dragion
Looking sharp...I like!
Thank you
Originally Posted by botlfed98
Wow looks super low!
It's low, I had to remove the rear fender liners but otherwise the stock wheels and tires from the 370z fit perfect. To give you an idea I took a picture, all that can fit between the gap is an envelope. No rubbing no rolling.
Hmmmm i do like moar low. Maybe swap someone for some 350z eibachs too. Im rollin the normal g37 sedan eibachs. Almost tuckin tire but i want that tire barely tucked.
so these aren't oem 370z springs? Is the Nismo spring a lowering spring for the standard 370?
No they are not, they are 03-08 350z Eibach sportline springs that drop the Z an average of 1.2 inches front and rear. As you can see I was able to get a little more than 1.2 inches when used on the G.
