Is there front sonar on the G37?
I always thought that there wasn't as I never heard any beeping when pulling up close to objects. However I read this in the manual:
Sonar Display : When this item is turned ON, the corner/center sonar indicator will appear when the parking sensors detect front or rear obstacles near the bumper. Then while searching on the internet, I see several sites that list front parking sensors as a feature on the G37 sedan. I'm going to assume that there is none, because in the diagram in the manual, only the rear sensor areas are shown. What would be a good, stealthy way to install front sensors? |
its standard on 2010's
think other years you needed tech package.. not sure on this part |
2010 does not have standard front sonars. I dont think g37 even have front sonars.
There aren't any front sonars in North American specs. I know they come with them in the middle-east market.
Well that sucks. Anyone tried aftermarket options?
oh front...
I was thinking rear..oops |
The "best" way to do it is to probably order the EU spec front bumper and parts. You also get headlight washers that way as they're required by EU law on all vehicles with HID headlights. However, that is not the cheapest way to do it.
Only the 2010's have sonars; however, you must get either the premium or navigation package for the vehicle to come equipped with the sonar sensors. Check on Infiniti's website, look at the package details, and it will inform you exactly which package comes with the sonar sensors.
We in the middle east got those since 07 for the sedan and 08 for the coupe. These are available both front and rear and come with a switch in the center console to turn them off. This is also available on EU and JDM G's. I think you guys get them on the 2010 model
Originally Posted by Q8y_drifter
(Post 2916586)
A bit overkill with a review view camera and pain if they're audible, would like to have the M's blind spot intervention system though.
Took a drive in a friends TL-S, I couldn't believe the damn seat belt alarm never went off. I'm so glad we don't have that anoying POS. |
They should have put it in the front instead, since we already have a rear view camera for the back.
Originally Posted by 6mtg37s
(Post 2916720)
i'd definitely like front sensors as well. i was surprised to see there aren't any.
front sensors are VERY helpful when getting out of tight spots. I'm pretty sure it won't take much to install the ones on the 2010 to the earlier models.
