*FIX for high-pitch frequency noise*
Old 05-29-2011, 04:40 AM
  #211
weiRDwei
weiRDwei's Avatar
G37 High Frequency Pitch
Can we confirm from the 'Fixed' users on what part numbers their ECM/ECU is?
And also what car/year/transmission. ECM/ECU part may differ dependent upon w/Technology package and/or auto or manual transmission.
I had mine replaced by Infiniti based on part number 23710-JK73D and my noise remains.
However, I have noticed several users with success on the fix based on part numbers and users who had it replaced.
23710-1ND6C - beerme986 - SUCCESS
23710-JU60C - t8er - SUCCESS
23710-1ND9C - CuthGood130 - SUCCESS
23710-JK73D - weiRdwei - FAILED
I have a G37 08 coupe automatic sport w/o technology pack.
ECM/ECU number 23710-JK73D replaced.
Noise remains!
Please check your paper work for the ECU/ECM replacement as it lists what part number was ordered and installed.
I hope my gathering of information helps those with this noise problem.
Bring the different ECU/ECM part numbers to your dealer and let them know which ones work!
Old 05-31-2011, 01:33 AM
  #212
ozzypriest
ozzypriest's Avatar
Originally Posted by germ3
The first dealership I brought it to claimed they couldn't hear the sound and that it was operating as normal. I don't understand how the car can be normal when there is a difference in sound between my G37 and the loaner G37. And how can you claim it is normal when you stated you can't hear the sound?
I think I'm going to bring my laptop next time. If you record your car running, you can filter out the high pitch noise in GarageBand using a Parametric Equalizer. Just set the Frequency to 10kHz, the gain to -20dB, and the Q to 20. You can also isolate the high pitch noise with a high pass filter at around 9.5kHz. I'm hoping these audio samples will draw attention to what they should be listening for.
HA! If only I 'd thought to do that!!! I bought a 39.00 iPhone app used by music pros to perform frequency spectrum analysis in order to diagnose and show to the service department. I was able to pinpoint the noise at right around 9950 hz. Once you boosted the input level by 20-30db, and narrowed the frequency band to that area, I was able to get a big fat peak many DB higher than the surrounding ambient noise to show to the service guys - my analysis showed lots of engine noise around 100-1000db, then nothing basically, then BAM! a huge peak at 9950. then nothing again, so it was real obvious, and I could recreate the data in real-time with my phone at the dealer - it was hard to argue while watching the spectrum analyzer live and in action, showing the peak going up and down as I revved above 1500, and then back down again.
I also insisted that they give me a tech who was young, and hadn't had his ears blown out by years of service bay work - he heard it right off the bat, and confirmed with the service advisor. I received no grief from anybody on this fix, and I think I was one of the first ones to get it. I am still whine -free a year or more later, although I get a crazy shriek from the ECU at redline, lol, but that I don't mind - it's probably a protest scream from my car, lol.
Old 05-31-2011, 08:49 PM
  #213
BKG37X
BKG37X's Avatar
You should try posting in the regional section as well. Infiniti of Englewood in NJ fixed my issue, and it only took 2 visits.
Old 01-25-2013, 03:16 PM
  #214
jktinen
jktinen's Avatar
Just took my 2009 G37x in for the whine noise. They told me it was "normal" noise from the throttle bodies and I was able to hear it because I had my front windshield replaced... Seperate issue was the engine knock noise, which only occured when the car was warmed up. They told me it was my radar detector. This is autoplace infiniti in Buffalo, NY. Going to pick it up tomorrow... We will see what they say when I show them the noise.
Old 01-29-2013, 12:44 PM
  #215
jktinen
jktinen's Avatar
The dealer agreed to perform the tsb for the engine knock after much duress and phone calls to infiniti.. The tech said the two noises were related, which i highly doubt. Ill repost an about a week when the new short block is installed.
Old 01-29-2013, 06:13 PM
  #216
huwee06
huwee06's Avatar
I learned to live with it, I tried to get them fix it but the tech said he couldn't hear it so it was a failed attempt...
Old 02-05-2013, 11:10 AM
  #217
jktinen
jktinen's Avatar
keep trying! after they replace the engine block I am going to investigate further. The tech said the noise was related but I think thats BS.
Old 02-06-2013, 03:46 PM
  #218
brizey
brizey's Avatar
I noticed that Tire Rack asks you if your car was made before or after March of 2010. I assume there was a running change of some sort. Wonder if this was it given the timing of the start of this thread?
My car is a 2010 built in April 2010 bought used a few weeks ago. My hearing sucks, but my wife and kids have never complained about it.
I could be just a bad lot of capacitors or transformers in the ECU.
Old 02-15-2013, 11:39 PM
  #219
jktinen
jktinen's Avatar
new block, "knocking" noise not fixed. High pitch noise not fixed..
Old 02-16-2013, 10:56 AM
  #220
Redpit
Redpit's Avatar
Im pretty positive they ask for the build because the tpms operate on different frequencies.
Old 03-06-2013, 10:56 AM
  #221
jktinen
jktinen's Avatar
Replaced my ECM with part # 23710-JU60C. This resolved my noise. It took me about 6 trips to the dealer to fix this. I ended up taking it to a different dealer about an hour away (Dorschel in Rochester) who were able to fix the noise on the second try. I highly recomend Dorschel for service.
Old 03-06-2013, 08:38 PM
  #222
jktinen
jktinen's Avatar
anyone getting the p1421 check engine code after the "fix"? I pulled off the lot and got this code and unfortunately the service dept was closed...
Old 03-06-2013, 10:25 PM
  #223
beerme986
beerme986's Avatar
If people get the that code after an ECM replacement. There is a reflash to make it go away. I believe I posted the details of it somewhere in this thread
Old 03-12-2013, 02:14 PM
  #224
jktinen
jktinen's Avatar
My fix was an "Idle air relearn." Ill post more deatils when I get the paperwork.
Old 03-28-2017, 08:44 AM
  #225
enuff4life
enuff4life's Avatar
Anyone got the reference number on this issue?
Quick Reply: *FIX for high-pitch frequency noise*
