Wheel offset
Old Dec 22, 2017 | 01:13 AM
Q6086's Avatar
Q6086
Wheel offset
Is 9x20 +25, 10.5x20 +40 a good setup? And if so what tires should i get? I have a coupe nonsport on tanabe coilovers.
Old Dec 22, 2017 | 09:05 AM
Not bad, you can run quite a bit of tire w/ those specs. A 255/35 front 295/30 rear.
Old Dec 22, 2017 | 10:13 AM
Q6086's Avatar
Q6086
Or is there a setup u would recommend?...i just want the wheels flush without poking out
Old Dec 22, 2017 | 02:36 PM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
You might find these links handy...
Below is the link to all of the OEM offsets
https://www.myg37.com/forums/wheels-...reference.html
Below is a wheel offset calculator from an online site:
Wheel Offset Calculator | 1010Tires.com Discount Online Tire and Wheel Store
By putting in the OEM specs, then putting in the new wheel specs, you can see how it will affect relative fitment.
How flush you want the wheels with the panels might be up to personal preference. But there seems to be a general consensus that increasing the outer position of the Sport rims by 20mm makes the top of the wheels flow flush with the panels.
My personal preference is 15mm
Hope this helps
Old Dec 22, 2017 | 02:43 PM
KAHBOOM's Avatar
KAHBOOM
9x20 +25, 10.5x20 +40 in my opinion might be slightly too much and will poke out by about 4 mm. However that might be something that you find preferable. If you are lowering your car and on 20s, it could be a really tight fit though. And depending upon how low you go and how much tire to get the likelihood of rubbing looks high.
I am on swift springs and I increased the outer position by 20 mms and my rears rubbed a little. So I went down 5 mms and it was perfect for my setup
Old Dec 22, 2017 | 03:27 PM
Q6086's Avatar
Q6086
Thanks and well ill play with the calculator and hopefully ill figure it out
mjnoles1
Jan 3, 2016 01:43 PM
IP37
Mar 23, 2014 07:32 PM
MaxdOut
Aug 17, 2009 01:14 PM
m500
The M - Spot
Feb 23, 2006 01:14 PM
