Overheating when idling
#46
I have no idea what it is. My temperature always reads +20 degrees higher than normal. The coolant sensor is behind the cylinder head? Then whatever I relocated must be something else. Im gonna snap pics of it in the morning. But yeah its been almost a month and a half now since I relocated this sensor and I have had no cooling issues.
#48
thx for the pic rice. and yes thats the coolant temp sensor. man from the looks of it it would be a real pain in the as s if the coolant crossover pipe gaskets were to ever leak on the back of these cars.
#50
without the proper tools, mechanical knowledge, and skill i do not suggest you working on or near the crossover pipe as it is way out of your league in difficulty. btw why would you need to access that area of the engine anyways i thought you stated you identified the ambient engine temp sensor issue already?
#51
#52
ambient temp sensor can also affect when the fans turn on
I know this is way late, but I just wanted to let you guys know that I found a solution to the problem. The overheating had nothing to do with the radiator or cooling fans. The thermostat came loose and was hanging close to the test pipes giving it false temperature readings. My car was not overheating the senor just picked it up that way. I drilled a slot in the radiator cover and made a spot for it there. Tbh, idk where the thermostat originally was. But now I have no false overheating issues
The Ambient temp sensor can control the fans depending on outside temperature.. all i wanted to add
