new tranny + clutch replaced under warranty
so im in my second transmission within a few months. the new ones seems fine little less noisy than the one before, some of th ticking issues i had dealer inspected and reported back to me.
clutch was still meaty (2mm left, they said .03mm is the min to get replaced.. or something like that)
service adviser said clutch isnt warrantied and if i wanted the ticking noise (clutch related issue. something to do with the internal spring) fixed then i should consider a new clutch since the clutch shield was the issue (and the shield + spring cannot be replaced since its one assembly clutch is part of it.)
he checked for me and called me and said the clutch shield/spring is a powertrain warranty item. so now i have a new clutch plus transmission on my car for free.
seems like this dealer went above and beyond what other dealers may go.
Wow do you mind posting up that repair receipt... I had a faulty CSC and was told it was due to vibration from my stock clutch. Had to pay out of pocket for another clutch since the dealer told me the clutch was a wear and tear item. But the master and CSC were replaced under warranty. You're one lucky guy.
haha, the service guy was great, he told me he was going to look into it but assured me the part number he typed in was covered under powertrain and said it was funny cuz that part comes with the clutch itself. he did tell me when i paid the 15 bucks for the loaner fuel "this is the first time i ever warranty a clutch"
on a side note, there are still some small noises and sometimes when i come to a complete stop and im waiting on either a red light or stop light and i release the clutch i hear clattering, i wonder if its engine related? it doesnt do it all the time but it kinda bothers me the times that it does do it. remind me of a Volkswagen weedwacker engine. other than that, the gears shift so much better!
if you hear noise coming from when you release the clutch, you have a chance to take it to the dealer, i know its a common issue and most dealers would replace it under warranty. they are paid to do the work so i wouldnt see why they wouldnt do it. worth a shot, as for me i did have issues coming from it and dealer also reported issues from the tranny itself. but yes
I get some crazy chatter sound after a spirited drive, and I think it could possibly be my throw out bearing, but I'm not sure on that. I'll shut the car off, turn it on a minute later and the ridiculously loud chatter goes away. From what I've read briefly online is a faulty throwout bearing can cause a clutch to wear prematurely? If so I'm going to see if my dealer will take care of my clutch as well....
I have a grinding problem going into 5th gear in the morning when it's cold, on a '08. I have an appointment tomorrow to get it checked out. The service tech believe's that it's the clutch. He said that if it's the tranny, it should be replaced under warranty. Have there been any changes in the G gearbox since 2008? I have a 2003 AP1 Honda S2000 and they changed the syncros from brass to carbon fiber in the AP2's. I had a 2009 G/B installed in mine and what a difference in shifting. It always shifted fairly smooth, but with the later G/B I can drop it into any gear, w/o any grinding.
