door handle sanded!
Old May 28, 2012 | 04:18 AM
xxg00w0's Avatar
xxg00w0
door handle sanded!
i just fixed my scratched up door handle... just feel like to share it with you all!
special thanks to member betterdayz on how to remove the aluminum part of the handle.
Attached Thumbnails door handle sanded!-img_1459.jpg   door handle sanded!-img_1462.jpg   door handle sanded!-img_1463.jpg   door handle sanded!-img_1477.jpg   door handle sanded!-img_1480.jpg
Old May 28, 2012 | 08:42 AM
TwoThree's Avatar
TwoThree
First mod I did to my car.
Old May 28, 2012 | 09:59 AM
DeamonG37s's Avatar
DeamonG37s
So you jus remove the handle and sand it and reinstall and it looks like that?
Old May 28, 2012 | 02:08 PM
xxg00w0's Avatar
xxg00w0
yes!
Old May 28, 2012 | 02:42 PM
ayarj12's Avatar
ayarj12
That's a pretty awesome water bottle
Old May 28, 2012 | 02:52 PM
Steveoh187's Avatar
Steveoh187
just discovered two decent-sized scratches on my passenger side piece after giving some friends a ride last weekend so I might be trying this, did you wet sand the trim piece or did you do it dry?
Old May 28, 2012 | 02:56 PM
TwoThree's Avatar
TwoThree
wet sanded, in one direction so it looks brushed, and then clear coated.
Old May 28, 2012 | 02:58 PM
Steveoh187's Avatar
Steveoh187
wet kind of clear coat did you use, just standard aerosol can? Also, did it match the rest of the interior trim exactly when you were done or do you think it would be worth doing both the driver and passenger side pieces to maintain a consistent look?
Old May 28, 2012 | 02:59 PM
TwoThree's Avatar
TwoThree
I'll get another picture once it stops raining.
Old May 28, 2012 | 03:01 PM
TwoThree's Avatar
TwoThree
Yep, Duplicolor. I wouldn't use it on much else, but for this kind of job it was perfect.
Old May 28, 2012 | 03:44 PM
xxg00w0's Avatar
xxg00w0
what kind of clear coat should i use ???
Old May 28, 2012 | 04:26 PM
TwoThree's Avatar
TwoThree
$30 and I'll just do it for you lol.
Old May 28, 2012 | 05:24 PM
jmueller's Avatar
jmueller
I used 400 grit paper, and it took me forever to sand them down. Start with something a little more abrasive than 400, then finish off with the 400 for a nice brushed aluminum look. I then polished with aluminum polish, 3 coats of duplicolor clear coat, and then waxed them up and reinstalled them. They turned out great, and look much better than all the scratches that existed before.
Old May 29, 2012 | 12:28 AM
Lucster's Avatar
Lucster
Anyone see the Infiniti water bottle..
Old May 29, 2012 | 01:20 AM
DeamonG37s's Avatar
DeamonG37s
yea that bottle is pump
