service engine soon, code p1421
Old Feb 16, 2010 | 11:48 AM
beerme986's Avatar
beerme986
I got a service engine soon light so I got the code ran at a local shop (for free) It was a p1421 - manufacturer control auxiliary emission controls. They cleared it saying it was probably nothing and if it comes back then to have checked out.
Yes I did a google search but they all showed for BMW cars, not sure if that matters. can anyone verify what this code means? car runs fine so im not too worried.
Old Feb 16, 2010 | 03:47 PM
ifinity's Avatar
ifinity
Engine control, service manual pg EC-406
COMPONENT DIAGNOSIS > [VQ37VHR]
P1421 COLD START CONTROL
Description INFOID:0000000001734223
ECM controls ignition timing and engine idle speed when engine is started with prewarming up condition.
This control promotes the activation of three way catalyst by heating the catalyst and reduces emissions.
DTC Logic INFOID:0000000001734224
DTC DETECTION LOGIC
NOTE:
• If DTC P1421 is displayed with other DTC, first perform the trouble diagnosis for other DTC.
DTC CONFIRMATION PROCEDURE
1.PRECONDITIONING
If DTC Confirmation Procedure has been previously conducted, always perform the following before conducting
the next test.
1. Turn ignition switch OFF and wait at least 10 seconds.
2. Turn ignition switch ON.
3. Turn ignition switch OFF and wait at least 10 seconds.
TESTING CONDITION:
Before performing the following procedure, confirm that battery voltage is more than 11V at idle.
>> GO TO 2.
2.PERFORM DTC CONFIRMATION PROCEDURE
With CONSULT-III
3. Select “DATA MONITOR” mode with CONSULT-III.
4. Check the indication of “COOLAN TEMP/S”.
If it is between 4°C (39°F) and 36°C (97°F), go to the following steps.
If it is below 4°C (39°F), warm engine up to more than 4°C (39°F) and retry from step 1.
If it is above 36°C (97°F), cool engine down to less than 36°C (97°F) and retry from step 1.
5. Start engine and let it idle for 5 minutes.
6. Check 1st trip DTC.
With GST
Follow the procedure “With CONSULT-III” above.
Is 1st trip DTC detected?
YES >> Go to EC-406, "Diagnosis Procedure".
NO >> INSPECTION END
Diagnosis Procedure INFOID:0000000001734225
1.PERFORM IDLE AIR VOLUME LEARNING
Perform EC-19, "IDLE AIR VOLUME LEARNING : Special Repair Requirement".
Is Idle Air Volume Learning carried out successfully?
YES >> GO TO 2.
NO >> Follow the instruction of Idle Air Volume Learning.
2.CHECK INTAKE SYSTEM
DTC No. Trouble diagnosis name DTC detecting condition Possible cause
P1421
Cold start emission reduction
strategy monitoring
ECM does not control ignition timing and engine
idle speed properly when engine is started with
• Lack of intake air volume
• Fuel injection system
• ECM
Revision: 2007 June G37 Coupe
EC-407
< COMPONENT DIAGNOSIS > [VQ37VHR]
Check for the cause of intake air volume lacking. Refer to the following.
• Crushed intake air passage
• Intake air passage clogging
Is the inspection result normal?
YES >> GO TO 3.
NO >> Repair or replace malfunctioning part
3.CHECK FUEL INJECTION SYSTEM FUNCTION
Perform DTC Confirmation Procedure for DTC P0171, P0174. Refer to EC-232, "DTC Logic".
YES >> GO TO 4.
NO >> Go to EC-233, "Diagnosis Procedure" for DTC P0171, P0174.
4.PERFORM DTC CONFIRMATION PROCEDURE
With CONSULT-III
1. Turn ignition switch ON.
2. Select “SELF DIAG RESULTS” mode with CONSULT-III.
3. Touch “ERASE”.
4. Perform DTC Confirmation Procedure.
See EC-406, "DTC Logic".
With GST
2. Select Service $04 with GST.
3. Perform DTC Confirmation Procedure.
Is the 1st trip DTC P1421 displayed again?
YES >> GO TO 5.
5.REPLACE ECM
1. Replace ECM.
2. Go to EC-16, "ADDITIONAL SERVICE WHEN REPLACING CONTROL UNIT (ECM) : Special Repair
Requirement".
>> INSPECTION END
Old Feb 16, 2010 | 04:10 PM
beerme986's Avatar
beerme986
thanks for all that info!
Old Feb 19, 2010 | 08:54 PM
beerme986's Avatar
beerme986
hm am I the only one who ever got this? Anyone know what causes this code?
Old Feb 20, 2010 | 05:06 PM
headup's Avatar
headup
Sadly, I have this problem now too. My part # was 23710-1NC4C. It would really irk me if this light can't be turned off, but at least I don't have that noise anymore *knocks on wood*. Next time I think I'll spend my $40K elsewhere....
Old Feb 22, 2010 | 05:26 PM
Pip's Avatar
Pip
Tighten your gas cap.
Old Feb 22, 2010 | 07:42 PM
beerme986's Avatar
beerme986
this is not a gas cap issue.
Old Feb 24, 2010 | 09:45 AM
beerme986's Avatar
beerme986
in case anyone is wondering, there is a fix coming for this soon within a couple months. They are working on a reflash to correct this service light.
Old Feb 24, 2010 | 08:50 PM
Wongster's Avatar
Wongster
So is there an actual problem with the engine or is it just a problem with the ecu that is triggering the SES light?
Old Feb 24, 2010 | 09:13 PM
beerme986's Avatar
beerme986
apparently it is just a sensor that keeps on tripping. better not be an engine problem!
Old Feb 25, 2010 | 08:54 PM
PhilH930's Avatar
PhilH930
I blame Toyota
Old Mar 31, 2010 | 11:48 AM
SkylineEX-S's Avatar
SkylineEX-S
I hope this is the case.
I've been getting P0456 a few times already and it is suppose to be a very small leak in the evap control system...
Old Mar 31, 2010 | 11:51 AM
TomieG's Avatar
TomieG
I have the service light as well. Where did you go to get the code read? Any local autozone?
Old Mar 31, 2010 | 12:18 PM
beerme986's Avatar
beerme986
yea autozone or local garage can read the code for you. I would just take it to the dealer, whatever is wrong will be under warranty anyway. 'service engine' lights are emissions stuff
Old Mar 31, 2010 | 03:42 PM
TomieG's Avatar
TomieG
Emissions...i see...the thing is i am reluctant to bring my car in for service because it has aftermarket cats, exhaust, hids, suspension, wheels. The light only came on after i installed my hids. Ive driven with the light on for about 1 week on Friday and its still on.
